steering rack
Old May 27, 2007 | 06:15 PM
micahdeane's Avatar
steering rack
ok i have been leaking power stearing fluid since i got the car around 3 months now. i noticed a few days ago that the boot that goes to my steering rack was torn and just hanging there and of coarse sliding up and down as i turn, i talked to a mechanic friend and he told me theres some ring in the rack that is probably bad so i need to replace it, but he said since i have 150k on the car i might as well change the whole rack while im there. my question is if i keep driving it the way it is (and keep adding P/S fluid) can i mess up anything else? thanks
micah
Old May 27, 2007 | 08:27 PM
you will just have an very very dirty undercarriage and if you plan to enter any kind of motorsports, you will not be allowed becuase leaking will get you kicked out.... my rack was leaking also..mainly becuase the tie rod boots were gone.. after i removed P/S and plugged the lines i was fine.. im not suggesting that.. also a Rack job is pretty simple..
Old May 27, 2007 | 08:43 PM
Replace the rack, if you just continue driving it it will only get worse. Maybe not right away, but it will.
Here's the rack, its just over $200
http://www.steeringrack.com/product_...oducts_id/4332
Here's a complete seal kit, just under $60. Keep in mind these are before shipping.
http://www.rockauto.com/catalog/rafr...c1208966k79589
How much $ is it worth to you to have the new rack?
Old May 28, 2007 | 09:18 AM
micahdeane's Avatar
for $200 i think i might as well change the rack, i just gotta talk to a couple friends to see if they can help b/c i have never done any change like that before thanks for the info
Old May 28, 2007 | 11:20 AM
No problem dude. You and a friend should be able to knock it out in a day. Better doing it yourself than having a mechanic rape you.
Old May 28, 2007 | 11:34 AM
I can understand overcharge, but rape?!
wtf were do you guy Ry?
Old May 28, 2007 | 11:42 AM
I dont go to a mechanic because I don't want to be raped!
Old May 28, 2007 | 12:11 PM
mercer goes to mechanic.........
Old May 28, 2007 | 12:18 PM
micahdeane's Avatar
yeah for some reason i never feel good after i get raped! lol
Old May 28, 2007 | 01:41 PM
My point exactly.
YOU STAY AWAY FROM THAT WEBSITE!
Old May 28, 2007 | 05:05 PM
micahdeane's Avatar
this may sound stupid but if i keep driving w/ it like the way it is and it ends up failing on me what would be the results? just loss of power steering or no steering at all or what? thanks again
Old May 28, 2007 | 07:45 PM
Loss of power steering. Worse for some people than others.
Old May 30, 2007 | 01:38 PM
micahdeane's Avatar
anyone know where i can find the steering rack bushings. i suppose that what they are called, they are at the end of the rods coming out of the rack on the inside of the wheel. thanks
Old May 30, 2007 | 01:57 PM
any bushing or bolt you need will be found at you local parts store or nissan dealer
Old May 30, 2007 | 03:25 PM
micahdeane's Avatar
is what i described the steering rack bushing?
