Stumped
Okay, here's the deal. My new 1996 240 5-speed has a problem. On the clutch pedal there is a thing that comes off that has two rectangle shaped things that come off and go into a rod that goes through the firewall. The two rectangle shaped pieces that are on the thing broke off and I can't drive my car. I just need to know what it is called so I know what to get.
Thanks, lucas |
pics? because all the things you just said totally threw me off
Is it the thing thats suppose to push the switch in cause if so i had that problem with my brake lights, i put some rubber thing in it so it would push the button in then wrapped it in tape, its a pain in the ass hope this helps
Get a new clutch pedal assembly from a junkyard
its the master cylinder sounds like the fork that connects it to the pedal assembly you will probably have to get a jy one since on most autozone rebuilt ones you have to swap that piece over. Nissan might sell the fork part alone.
Originally posted by -HyJynX- Get a new clutch pedal assembly from a junkyard |
