sweet lord it's back
okay you know the problem i had when my RPMs dropped real low in neutral and everyone said "new fuel filter" so i got the new fuel filter and when i cranked it all seemed good then i was driving it and in neutral the RPMs again dropped real low and the dash lights dimmed... is there enything else that could be wrong with this? cause its starting to really piss me off now
Defective Idle control valve
Defective fuel pressure regulator If you haven't already you should have your battery and alternator tested. At most auto parts stores you can get both tested for free. Have you done a full tune-up? |
i dont know wat u mean by low rpm's. can u give us a #? remember, MT = 750 rpm and AT = 700 rpm. iono if u knew that or not. I had low idle b4, sounds like the car is dieing huh. :) :(
their dropping way low... around like 100 rpms or sometimes 200... then when at a dead stop they flutter from high to low and low to high finally settling around 750 rpms
i just hope she isnt dying... i need another good 5 months out of her before i have enough to get my new engine... |
check the vacuum hoes my car was doing the same thing and it was because one of the vacuum hoes was leaking check the ones towards the end of the intake manifold close to the firewall it hard to find of you don't know what you are looking for
Yea my Camaro was having idling issues too, it would hang at about 1500 before settling down to 800. It turned out to be a bad gasket on the intake manifold. So I'd start by checking all your vacuum lines. If they are all good go buy a can of Carb cleaner and spray it around the edges of your intake. If you gasket is bad then the carb cleaner will get sucked in and the engine will stutter and maybe even stall.
