Thermostats
Old Jun 29, 2005 | 07:04 PM
Shri222's Avatar
Question Thermostats
I got a CA18DET ,but this question helps all motors and is the same for all motors. MY CA thermostat is set at 195 degrees. I want to run colder I have a 180 degree thermostat, I also had a 160degree thermostat. Would dropping the temp 15 degrees work well or would the motor not reach peak HP. And I'm figgering 30degrees is to cold ? how would it work with the ECU etc.. I know cooler temp usely boosts power, that's the principle behind nitrous and the point of using a bigger radiator.
Old Jun 29, 2005 | 08:14 PM
Shri222's Avatar
common i need help !! :-p
Old Jun 29, 2005 | 08:16 PM
Slidin240's Avatar
c'mon Shri chillax give it sum time, its only been an Hr since you posted it... you'll get some replys
Old Jun 29, 2005 | 08:17 PM
Shri222's Avatar
i'm impaciant :S
Old Jun 29, 2005 | 08:28 PM
Black240Coupe's Avatar
well my KA had a stuck open thermostat when i first got it.. the car ran like **** cuz it was runnin to cold.. i threw a new thermostat in and all my problems were gone..hope that helps?
Old Jun 29, 2005 | 08:30 PM
Shri222's Avatar
how much colder were you running?
Old Jun 30, 2005 | 02:22 AM
lrb_2000's Avatar
probably really cold if it was always open...
what's wrong with 195 degrees? I would say 180 would be safe... but you don't want the engine too cold or the oil isn't happy?
Old Jun 30, 2005 | 07:32 PM
Shri222's Avatar
well the oil i can always a heavyer weight oil 40HD vs the 10-30 i use now that solves the temp viscocity problem. HD 40 is 40weight cold and hot
