things wrong with your car list
Old Dec 19, 2004 | 12:22 AM
  #61
ixcocoyxi's Avatar
stolen...
i won!... err.. lost..
Old Dec 19, 2004 | 12:37 AM
  #62
WILDACEXXX's Avatar
sunroof leaks
1 small rust spot around sunroof
backfire
rattling catalyc cover
cracked dash
HUD and digital speedo only work when they warm up
alingment sux
1 headlight is lower than the other
ka burns a lil oil
Old Dec 19, 2004 | 08:18 PM
  #63
MTDrift_SR240's Avatar
Did i mention 311,000 miles?
Old Dec 20, 2004 | 04:17 PM
  #64
phreze's Avatar
Speaking of gay stickers there is a sticker on the car I was looking at that says "ALWAYS FORWARD, NEVER STRAGIHT" with the straight being rainbow colored. Along with some dragon stickers and a bent driverside door.
Old Dec 21, 2004 | 02:41 AM
  #65
lrb_2000's Avatar
My old 89 coupe:
burns and used lots of oil
smokes bad
needs painted (flat black now)
needs alignment
flip up lights suck
bad throwout bearing
Old Dec 21, 2004 | 09:44 AM
  #66
twofotisx's Avatar
my rear trunk lid is all frucked from removing the factory spoiler, was removed because it was causing massive rust buildup
because of the freezing weather I fixed it quickly with spray foam insulation to stop water leaks
passenger door must have window lowered to close
signs of engine knock are becoming apparent (fruck)
130k so not that bad (should run to at least 210)
wiring on my car frucked from previous owners alarm job so i'm constantly replacing fuses and bulbs
an O2 sensor that refuses to move out of my headers so I can replace them (will have to be cut off)
steering wheel that when has a little mosture on it turns my hands and pants black
no rear defroster
A/C works but even with new belt the damn thing screams
no radio
have an S13 so when ever it we get snow or sleet I have to make sure my headlights pop open
bad rips in leather seats (driver and passenger)
hole in carpet interior close to drivers seat (about 2 inches big)
just had to replace my entire steering rack
other than that it's in great shape and I love it!!
Old Dec 21, 2004 | 09:48 AM
  #67
twofotisx's Avatar
oh and I forgot,
the passenger front fender is messed up from a fight with fox, it lost badly
tires that are almost down to the belts
blown front shocks and springs, and blown rear springs
Old Dec 22, 2004 | 01:10 PM
  #68
Originally posted by l2aine
1. Needs major paintjob - lots of scratches, dents, dings, and a roof that feels like sandpaper
2. The common timing-chain-guide-making-noise crap - next on my list to fix
3. A/C doesn't blow cold when turned on and heater doesn't blow hot - the only thing that comes out is outside temperature air
4. Windshield has this one crack that is like perfectly aligned with where the driver usually looks forward
5. Is your power antenna broken? Mine isn't even THERE. All I have is the hole.
6. Speaking of, there's like 3847297843 holes in the trunk from previous owner's rear wing experimentation (thus part of #1 above)
7. Drop drop drop oil spots in my garage
8. Needs a new steering wheel - if I grip the top part long enough, parts of it will magically stick to my hand
9. I own a 95 Zenki, so "naturally" my headlights are yellowish during the day.
10. Moonroof has a 1/4" gap in the rubber moulding that lets rain drop perfectly centered onto the armrest in the center console.
11. Clutch pedal is squeaky
12. Spare tire wheel is yellow (to match the headlights?) Wait - that's normal. Nevermind
#2 fixed - removed timing chain guides
#3 fixed - replaced entire A/C system with a brand new one
#5 fixed - got a manual antenna installed for radio reception
#7 fixed - it was actually p/s fluid, but I installed new tie rod boots
#8 fixed - replaced stocker with a Bride wheel
#11 fixed - good game grease
ADDED #13. Clutch slips now damnit
ADDED #14. Tires need replacing
ADDED #15. Power steering pump seems to be dying out on me
ADDED #16. Heater core might be clogged
Old Feb 22, 2005 | 12:31 AM
  #69
KeN VeRsUs RyU's Avatar
bent tie rod ends and tie rod. Bad rear shocks. actually all four are bad. i need an alignment. Some scratches and dings on the door and rear fender on passenger side.
Old Feb 22, 2005 | 06:20 AM
  #70
s13_peacekeeper's Avatar
bad head gasket
coolant leak some where!
needs new breaks
runs like **** and cant find out why?
and right now i drive an 83 blazer s-10 :-(
Old Feb 22, 2005 | 06:30 AM
  #71
98cwitr's Avatar
summarized list
dents (some major some minor)
door handle (driver's side) broken, new one on order
Oil leak out of the timing cover
running very lean
car shakes (at idle and jumps/shutters at 3,100 rpms)
differential makes noise when reversing
will add to list if i think of anything else
Old Feb 22, 2005 | 07:59 AM
  #72
pooptown's Avatar
89 240sx
leaky hatch, had some water in with the spare tire
spoiler is comin apart
hole in the radiator
hole in block, water mixes with oil
bent valves
possibley blown head gasket
front lip needs repainting
paint is fading a little on the upper part of the rear quarter panels
busted speakers
radio doesn't work
kinda dirty engine bay
pieces of plastic are missing from the left side of the ciggarette lighter, so there is a square shaped opening(if anybody knows what goes there let me know)
and that's all the problems with my car
hasn't even made it to 70,000 miles so it's not in bad shape
Old Feb 22, 2005 | 11:08 AM
  #73
SlickSX's Avatar
aight here we go:
-some rust
-cracked fan
-gas always shows 1/2 tank all the time - if my odometer goes im really screwed
-really bad seat covers, but better than the actual seat itself
-even worse floor- big ups to walmart for floor mats
-no radio
-no antenna
-cigarette lighter wont stay in
-cracked center console thing
-scratched up AC buttons
-driver door never closes on first attempt
-cracked windshield
-ungodly noise when in reverse sometimes
-clutch squeaks and doesn't come all the way out
on the lighter note the car runs. and got it for free...can't beat that. also it doesn't stink in the ride....
Old Feb 22, 2005 | 01:27 PM
  #74
DaPCWiz's Avatar
UPDATES:
Originally posted by DaPCWiz
Lets seee where do I start, haha
- left side is mismatched due to some ***** hitting my door, but she's going into th body shop soon to be all fixed and pretty again
fixed - painted by body shop
- my air bag light blinks for no reason, and I'm too cheap to have the dealer look at it, imma just take the bulb out soon
fixed - reset airbag computer
- little scratches and dings, minor stuff....
- my right window makes strange noises, my left window doesn't even close right (but that will be fixed soon)
- my headlights used to be yellow and I polished them and now they are much less yellow
- the lights for the HVAC system don't come on
- heat shield rattle
fixed
- front suspension squeeks over speed bumps when it is under 35 degrees out(will get new suspension soon)
- rattle in the dash somewhere on the right side... I CAN"T FIGURE OUT WHERE IT"S COMING FROM, ARGH!
found it, will fix soon
- driver's side and interior mirror shake like crazy a good amount of hte time, so if I try to see what's behind me it's all Blurrrryyyyyyyyy
fixed by body shop
- my alignment seems a tiny bit off, while going like 80 on the highway, it veers SLIIIIIIGHTLY to the left...
will fix after new rims/suspension
I guess she's not so bad... I love my car
new problems:
- spoiler rattles somewhat
- driver's window regulator is busted
Old Feb 22, 2005 | 06:04 PM
  #75
wikd240's Avatar
well hell lets start with this...
multicolored front end (red and white)
bad alignment...
bad tie rods...
bad tie rod ends...
bad front end bushings...(every one)
bad shocks...
bad springs...
motor is in pieces...
torque converter messed up...
bad rear bushings... (all of them)
trunk leaks...
sun roof leaks...
interior has rips tears...
hud not working...
no dash light...
no radio or speakers...
no radio brackets...
stereo wires running all over the place...
bent radiator core support...
no antenna...
all of this is being fixed in the nex month... i have to have a totally functioning car in the next few weeks... spending all my mad money and money that aint mad... if i got a penny it is spent on the car...
