things wrong with your car list
Old Feb 22, 2005 | 09:48 PM
  #76
Chiefgmsr's Avatar
Got an alignment but the guy said I needed new struts. OK so he said he'll the best he can since I knocked my alignment out of whack. Now my passenger side rear wheel is perfectly straight. While the other 3 have a slight negative camber to them. Now which is right the 1 straight tire or the other 3. My car isn't even dropped yet.
Old Feb 23, 2005 | 07:24 AM
  #77
drnovascotia's Avatar
Think I got you all beat. . .
No interior, front end stripped, holes from spoiler, rear signals and antenna, 3 foot hole on drivers side fender. . in hundreds of pieces
Dr.
Old Feb 23, 2005 | 09:26 AM
  #78
twofotisx's Avatar
wow.... That's looks like it's been drop kicked off a plane...
Tell me that isn't your main car and that it's a project.
Old Feb 23, 2005 | 04:49 PM
  #79
Fast1One's Avatar
ok...
-Engine bay is really dirty
-Burns and leaks oil
-Does not turn on when its cold(does not crank over, have a new starter, weird)
-leaks antifreeze(only a little but still)
-bad tires
-rear passenger tire deflates
-Fender is dented, cracked, warped, everything that can happen to the body plus its painted orange (My car is red)
-broken left turn signal
-font lip is trashed
-Small dings and dents on hood, quarter pannels, and fenders
-Spoiler is VERY faded
-Shakes when I go 50 and 60( any suggestions? Maybe bad rims?)
-Exhaust has a leak and rattles like a biatch
-bad gas mileage
-steering makes wierd noise when I turn.
-Idles weird
-little rust
-smokes when cold and when I floor it( big POOOF embarasing)
-Ripped seats
-No floor mats so every square inch of the carpet is stained
-Random missing interior pieces
-Cracked dash and door panels
-leaky trunk, wheel well full of h2o
-smelly because of the water plus I found a DEAD RAT in the trunk(:shiver
-Passenger lock hard to open
..And finally...
-No lock for the hatch, I took it out because it had a broken key inside, still doesn't work. Does the trunk have a diff. key? ( and no that is not where the water leaks it leaked before I took it out)
Im sure theres a lot more i have not found yet but i LOVE my car.
Old Feb 24, 2005 | 06:33 AM
  #80
DaPCWiz's Avatar
alignment? balancing?
Old Apr 1, 2005 | 09:52 AM
  #81
drew935's Avatar
dang Doc, I think that you do have us beat.
With mine:
Dents on all fenders
one busted foglight lens
spoiler has created a lil rust spot
hvac ill lights (will fix soon)
Need to replace the the suspension
the common worn out spot in the driver's seat
windshield has many pits from rocks
tweeters need a better crossover
replace rear speakers
hatch lid needs new shocks
cracked dash
tint is a lil messed up (my fault)
All the other ones are from when I bought the car
Old Apr 13, 2005 | 10:29 PM
  #82
Sevarg710X's Avatar
Probelms with my 240 ....
-Oil all over engine from valve cover leak that's been there god knows how long
-Weird idle
-Jumps out of reverse (5 Spd.)
-Usual leak in the hatch
-Suspension shot
-dents all over
-Wrecked front driver side
-Driver headlight won't go down all the way
-Front engine seal leaking 3 quarts a day
-Alternator belt just broke
-Spoiler half ripped off
-Engine makes weird howl and knocking sound
-Misc. Missing interior pieces
-Broken driver side visor
ect ect I could continue , but that's not any fun now is it ? Other than that i can still blow away anyone I race around here with only coll air intake :-D
Old Apr 13, 2005 | 11:56 PM
  #83
lrb_2000's Avatar
Problems...
-Negative Camber on all 4 tires.
-Needs new tires due to that ^
-Nice big dent in drivers side door.
-Tranny has a high pictched howling sound in 2nd and 3rd gear.
-A/C doesn't work.. was never used either as far as I know.
-Doesn't have a rebuild/turbo kit.
-Pulls to the right and vibrates at 25mph even after an alignment. (tires?)
-Left front shock is blown (I think)
Yeah, I think that's it... It runs perfect, and only has 100k miles.
Old Apr 14, 2005 | 07:05 AM
  #84
gunline_boss's Avatar
timing chain rattle
driver side tint peeling
slipping clutch
Old Apr 18, 2005 | 03:30 PM
  #85
Fast1One's Avatar
. [/B]
Bent Rim? Or tires. Or both. When I got my FNO1R-Cs my car stopped shaking. Have you balanced the tires?
Old Apr 18, 2005 | 04:14 PM
  #86
naptime's Avatar
only thing I can thinkof right now is an oil leak from the valve cover. In need of a gasket.....only $12, I just need to get them. Is there a bolt pattenr I need to follow for the bolts when putting the cover back in or taking it off? I can't seem to find my chilton
Old Apr 18, 2005 | 04:17 PM
  #87
Fast1One's Avatar
There is just not sure what it is (im no help lol) Its something like starting from the center and working your way out.
Old Apr 18, 2005 | 05:02 PM
  #88
DaPCWiz's Avatar
you can get the FSM from www.phatg20.net and it has the procedure for removal /installation.
Old Apr 20, 2005 | 08:27 PM
  #89
slimbung's Avatar
yeah i have one problem that i know of so far...
anyone ever had any broken tranny mounts?
oh and also my clutch is shot., and also the center console is dryrotted.
Old Apr 21, 2005 | 06:15 PM
  #90
LA_phantom_240's Avatar
well i think i got you all beat!
>crap *** original paint, which is faded and looks like a crappy custom chameleon gone wrong,
>door panels the look like a shew tried to eat em,
>cracked plastic around radio,
>all the leather is worn off or rotten away on shifter,
>the seats (leather) are so sun beaten they split themselves at every seam and for a time my 240 was parked away from my home and a bum decided to make it his home for a while,
>rear seat the wont fold down (fastback) because one of the stupid plastic thinks broke off
>smells like it burns oil, but doesnt
>was parked in my yard for about a year, so the exhaust is so rotten i have a OEM fartpipe LOL
>leaky headers
>funky idle
>4 year old 93 octane fuel
>rotten rear speakers
>dent in rear quarter panel drivers side just before tail light from my stupid neighbor's for f-350 fagmobile, but cant prove it was him
>headlights that pop up wont wont turn on
> bad radiator
> broken tail light switch stopper, so they stay on all the time
> isnt registered
>isnt insured
>has a brake tag that expired 3 years ago
How bout them apples
