Tranny problems!!!
my car is acting soo stupid right now.. just a few days ago the clutch was perfect then today when i go to step on the clutch there was no pressure at all.. please someone help me so i can get the car back opn the road
It is most likely either the clutch master or slave cylinder. Peel back your carpet under the clutch pedal on the inside of the car. If there is fluid leaking into the car then it is a bad master cylinder. If that is not the case, look and see if fluid is leaking from your clutch slave cylinder, under the car connected to the bottom of the transmission.
Master cylinder is what the pedal goes into, but like I said, it will leak into the car. The fluid shouldnt be red as far as i know, but who knows what's in there. Just fill up the resivoir and see if it's leaking from the slave cylinder, you can't miss it, its attached to the bottom of the trans. and there is a hydraulic line coming out of it.
sir you need a new slave cly( on the tranny) and you need to bleed the car.
if that doesn't work like they said see if the slave cly ( engine bay ) is not busted by pulling the carpet back and checking for leaks.
idk when they started but it comes in handy. unfortunately the don't have many online manuals for newer cars. the ones they have are basically haynes manuals which are not my first choice but it's better than having to buy a manual per car. they also have some other usefully resources.
