Turn Signals Don't Work!
Old Jan 10, 2005 | 09:06 AM
DaPCWiz's Avatar
Amolao - good advice... ur car is mint bro, I just check out ur site.
the url you have in your sig doesn't work tho, you have to use: http://home.sw.rr.com/longstorenissan/
Old Jan 10, 2005 | 04:36 PM
Amolao's Avatar
THanks, please check out this link, is my car after a recent paintjob, need to update my webpage to reflect the new mods..... kind of busy lately...
http://********.com/zerothread?id=94479
oh and nice clean ride you have.....
Old Jan 11, 2005 | 12:10 PM
Wakuwakusan's Avatar
i had the same problem, and it did turn out to be a stupid fuse. The only problem i had and still have after that situation is that my rear turning signal lights are always on.
Old Jan 12, 2005 | 09:59 AM
First of all, replace the fuse with a brand new one. Old fuses can visually look fine but may have a break in them from time.
Second - check if your hazard switch is unplugged. If it is, your signals won't work at all.
Third - check the multiflasher-relay (a.k.a. combination relay). 240's use a special relay found under the dash, I believe on the left side of the steering column (check an FSM - I ended up repositioning mine near the fuse panel when I accidentally crushed it). If that relay is bad, expect to pay about $24 at the dealer for it.
marilyns14
Oct 4, 2005 02:20 PM
DarkDragon
Aug 14, 2004 01:55 AM
rb240sx
Aug 9, 2004 12:34 PM
[GoaTSLonG]
Jul 18, 2003 07:21 PM
Condom_Sense
Jul 27, 2002 03:20 PM
