Weird A/C Issue
Weird A/C Issue
I just recently hooked up my a/c (went 6 months with no ac after I had the engine put in) but after like 10 minutes of being on, it starts to blow warmish.
I push the AC button and the circulating air button both off, then on again, and it starts to get cold again, but keeps donig it. Any ideas?
go to the auto parts store and get a can of 134 freon... you can get it over the counter since it is r134... get the one with a gague and follow the directions... sounds like the pressure switch is tripping because it is low on freon...
the way to test this is... remove the pressure switch on the dryer... metal tube mounted under the battery,,,has a 2 wire switch on top of it... unplug the switch and use a small wire to jumo the 2 wires as they go back into the car... if the ac stays on then what is going on the system is low on freon... fill it and then plug the switch back in and see if it keeps going...
onelove240
Mar 22, 2008 07:50 PM
