What should I get? What do they do?
Old May 22, 2005 | 03:42 PM
th3br4d's Avatar
Well, I got 100 bucks and I want to buy something for the ol' 240 Well, here is the stuff I found I would like to know what they do and if I should get them or not.. Also, tell me if you know anything about the product like if it is trash or if it is a great buy.
Rear Lower Tie Bar
Ground kit
Short Shifter
Knology Hot Wires
Rear Ladder Bar
I want to drift in the future so tell me if any of this stuff would be bad for it.. Thanks guys!
Old May 22, 2005 | 03:50 PM
Fast1One's Avatar
I really dont know much about the parts needed for drifting...but im sure a short shifter wont hurt you no matter what your doing
Edit: Do you have coilovers? If you dont save those 100 bucks and put them towards some quality coilovers. Im pretty sure you'll need those for drifting
Old May 22, 2005 | 04:08 PM
lrb_2000's Avatar
Lets see.. the wires are pointless and way overpriced i'd say, especially if your car is mostly stock, wires don't really add that much to be spending 170$ for... you can make your own ground kit for cheaper...If you're going to get a short shifter, get B&M not some cheap s**t.. they're bad quality, and would probably break if you're going to be drifting and shifting quickly... I'd get the other two things.. or save it..
Old May 22, 2005 | 04:24 PM
Slidin240's Avatar
get the rear ladder bar, lower tie rod, or a good short shifter. If your gonna get em off ebay, just get the ladder bar and the Nology wires
Old May 22, 2005 | 05:00 PM
silviadriver's Avatar
- lower tie bar: that wont do ****, our cars is already stiff right inbetween the wheels, buy this if your car is a honda
- ground kit: waste of money only works between certain rpms for example: 4500-5000rpm
you want ground? go to your audio store and buy ground wire there, same ****
- short shifter: Nismo? hahah wat a fake. buy b&m and be happy
- hot wires: same, wont do ****
- RLB: works, only item here that will work with "drifting"
fact is, you dont need ANYTHING to drift. go drift your bone stock ride. buying stuff will only HELP you IMPROVE your skill, but doestn MAKE you drift
Old May 22, 2005 | 05:05 PM
Fast1One's Avatar
That sounds like a FAQ Seriously though you speak the truth silviadriver
Old May 22, 2005 | 05:23 PM
ConceptS14's Avatar
if those are your only choices, then save your money!
Old May 22, 2005 | 05:37 PM
Slidin240's Avatar
if really want to spend that 100 bucks then buy suttin if not juss save it and buy suttin better later on, like a LSD. thats suttin that will really help you out when drifting
Old May 22, 2005 | 06:44 PM
DriftOrDieTryin's Avatar
non of them save up and buy my **** lol
Old May 22, 2005 | 06:47 PM
Fast1One's Avatar
That is so true man...
Old May 22, 2005 | 07:39 PM
I'm with Stupid's Avatar
Don't be a poser, buy tires.
Old May 22, 2005 | 07:41 PM
Fast1One's Avatar
Yes tires are the one of the most important aspect of your car so dont skimp...
Old May 22, 2005 | 07:47 PM
th3br4d's Avatar
I already have tires you nub! Kumhos =]
235/55/17 on the back (I think)
215/45/17 on the front
Old May 22, 2005 | 07:49 PM
Fast1One's Avatar
Me a nub? HAH! Well then def. work on suspension.
Old May 22, 2005 | 08:00 PM
zero.counter's Avatar
Some aluminum collars? Pineapples, cheap a$$ lowering springs, etc...
