where is the IAT at???????
I can't find the iat "Intake Airflow Temp. senceor.. can any body point me in the righ dircetion? Is it the harness that is on the mafs??? where is it???? hellllllppppp...
that is what i thought it was too. the two harnesses under the air box but i am not sure. it has the two wires going to the harnesses that are put together. i am still scratching my head...lol....
^^^it does. i didn't buy the ebay thing but i found out the resistor ohms used, 4.7kohms, and i put one in. well it makes a slight but noticable difference 4.5-5k+ my car used to slow down and not pull much top end. now it has it.
you buy the resistor, unplug the IAT harness, bend the leads on the resistor so it looks like a U, then insert the leads iinto the harness side clip, put take over it to seal it, then you cna let it dangle or secure it to someplace. and if your keeping the stock airbox i would seal up that connector with tape so it doesn't get dirty
Always showing too much cold air, dumping too much fuel, running to rich, ect, ect....
It's a "performance" mod for those who dont know better. Then something goes wrong with the car & they post on here wondering why.
lol well you know what. my butt dyno sees a difference. answer yes or no does it in fact increase power/acceleration slightly. cuz i think it does. and my car is a $200 beater so i don't give a **** about it. it's my first 240 which i'm gonna ahve fun with. the engine is suprizingly running good.. i misshifted today. all my gears grind when i shfit to fast so it gives me toruble and i hit 2nd from 3rd.. yeah i hit 8krpms. i was expecting the motor to blow but it's still running strong. my next 240 i won't do this.
s14kat
Sep 25, 2004 12:28 AM
