Free HP/ Cheap HP
Old Jun 4, 2007 | 09:10 AM
just an example of what an manifold with all the emissions crap gone looks like.. i converted my new s14 manifold back to obd1 and also deleted every un-vital thing
With Emission..
Without..... so much space and cleaner looking
Old Jun 4, 2007 | 01:08 PM
epp_b's Avatar
How much power to get by uncrapping it? How much would I get by removing the cat and having an open muffler.
Old Jun 4, 2007 | 01:38 PM
clubredsilvia's Avatar
^^^biggame, i want to get rid of all my emissions crap, but every write-up gets wrapped up in conversation or dosent include pictures. Can you please tell me EXACTLY what to remove, where to plug things, and what to do? I live i florida and i'm the only 240 kid with egr/iacv/crap.
Old Jun 4, 2007 | 01:55 PM
basically all you need is the vaccum from the check valve and the iacv. everything else can go. IIRC.
Old Jun 4, 2007 | 11:37 PM
re037's Avatar
vacuum for fpr needs to stay
Old Jun 5, 2007 | 03:56 AM
na it doesn't.. you can use any vacuum source for the FPR i generally used the one right of the back of the manifold.. i don't like to T that .. also the s14 manifold is sooo clean when striped down and you also have like 5 free vacuum spots... ill post some more later gotta go to work i swapped my motor last night and im just getting done at 6am.............. later
Old Jun 5, 2007 | 05:39 AM
FPR=fuel pressure ratios? guess. are those the vaccum lines than run into the black canister looking thing on the front driverside?
Old Jun 5, 2007 | 08:45 AM
BigVinnie's Avatar
Hey Bigg you don't get a check engine light removing all those vacuum lines?
Old Jun 5, 2007 | 01:52 PM
no sir Mr Vinnie
Old Jun 5, 2007 | 02:19 PM
BigVinnie's Avatar
Lucky MutherF$%ker with a FED issued ecu. Hey Bigg next time you come across a auto 91 or 92 ecu can you do me a favor and ship it off to me. I want to get rid of the CALI issued ecu that I have. Code 32 sucks and I am looking to get rid of the EGR temp sensor, and do an egr block off. This would even work better for me when I go to do my smog emissions check.
Old Jun 5, 2007 | 07:49 PM
  #26
will do... i should be going to the junkyard to pick up another pignose
Old Jun 5, 2007 | 08:11 PM
  #27
BigVinnie's Avatar
I need a 91-92 auto fed ecu, and 89-90 won't work.
Old Jul 10, 2007 | 11:04 AM
  #28
I went to the Junkyard man.. no luck ill keep looking bro
Old Jul 10, 2007 | 12:03 PM
  #29
BigVinnie's Avatar
Thanks for lookin...
Old Jul 10, 2007 | 01:19 PM
  #30
Torby's Avatar
1. Enough cold air
2. Good exhaust. Wrap your manifold in Thermotec. Hotter exhaust gas escapes quicker.
3. Make sure your intake doesn't have any obstacles. Match ports and gaskets. No point in porting the intake if the gasket is in the way.
4. Make sure it gets the right air/fuel mixture.
5. Change your oil and filters often. Use the right oil.
There's no quick, easy or cheap way to lots of power.
