Can someone point out a good how to on speedometer problem!
Can someone PlEASE point out a good how to on speedometer problem!
i have a digital one, my odometer doesn't run either. the display doesn't light up at all.
please help
please help
I did check fuses...
any special fuse that people with the similar problem had to check?
or any good how tos
i have searched. but want to run a check before i change the speed sensor.
please and thanks
or any good how tos
please and thanks
I searched a couple forums but only came up with this so far...http://forums.********.com/zerothread?id=158878
THANKS ! ! !
that Could, be my problem. . . i emailed and asked if the ODOMETER still turned, (kept track of the mileage).
Because mine doens't work, neither the speedometer (doesn't light up) or the ODOMETER (doesn't keep track of miles).
hopefully he answers...
or if anyone else knows . . . does the odometer still work with a bad capacitor.
FYI : He just replied! ! ! that was super fast!
The odometer DID RUN
so, thats not my problem! i was looking forward to doing that soldering! man!
for the capacitor to be the faulty, the HUD doesn't come on, and the odometer DOES run
any other ideas?
any other ideas?
here s another question . . .
for those who have changed the speed sensor . . . .
did the odometer still run ? ? ?
if it didn't, then ill change the speed sensor ! ! !
Can some one second that ^^
I have read all sorts of different versions, some it only turns once per 30miles. some continue running, some don't run.
Please someone second that ^ and ill change the speed sensor and do a follow up!
en
en
Speed Sensor
It will be the speed sensor that is your problem.
If you have no Odometer movement and no speedo movement that indicates a faulty speed sensor - However most cars will throw a CEL (check engine light) when the speed sensor is faulty.
Holder350...
Auto Parts Professional
Holder350...
i might be late answering but,nope it wouldn't have to run. about 4 months ago my car was idling for about 15 min. i had reset the trip odometer to see if what you asked would happen because the speed would read form 0mph-20mph. the needle would just jump while the car was parked. after some time the trip odometer read about 1/4 mile.
i replaced the sensor and nothing happened the problem persisted. i just gave up on it and until last week it read 15mph more than the actual speed. for some reason it just started working on it's own. i don't really care because i know how fast i'm going depending on what gear i 'm in and the rpms.
for example 3rd gear @ 3k is 35mph
