How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Bee-R revlimiter Install Diagram
Old Feb 13, 2008 | 10:36 PM
it cuts ignition not fuel.. fuel cut is deadly
Old Jan 24, 2010 | 01:03 PM
khmerxs13's Avatar
i know this is an old thread but i need help with the setup i cut the brown wire because it is a 4 cyn and also where do you connect the white wire to also how do you adjust it when i tryed to start up and let it idle it doesn't an my limiter goes off
so basically the limiter is going when starting up and about to idle how do i fix that
for to mention it for the sohc
Old Jan 24, 2010 | 02:44 PM
the white wire goes to nothing.... RE means Rotary
you have to adjust your yellow **** up to at least 5 or so.
also I hope you didn't wire it up off the diagram that I posted... that is for a DOHC.. check you FSM for the right pin outs
don't worry about this thread being old.. you did right by posting here.
Old Jan 24, 2010 | 03:00 PM
i was gona get this but then i realized i dont need it cause i can do it with my EMS lol
Old Jan 24, 2010 | 03:04 PM
yea i am no longer a Bee R user...
even with moderate usage.. it still blew my gaskets away.... turbos were fine. but I got tired or blowing gaskets.
Old Jan 24, 2010 | 05:18 PM
khmerxs13's Avatar
crap so the wiring diagram was for a dohc and the white wire goes to nothing i wire to the e brake because i saw another diagram on nico
also if i need the pinout for the sohc how are you gonna wire it up
like what wire goes to what
yellow-what pin or color
red
green
Old Jan 24, 2010 | 05:58 PM
AHHH that white wire.. sorry, its optional... you can use it for a poor mans two step.. but its not a needed part in the wiring.
I wired the wire you speak of to the clutch pedal.. but when I would clutch kick hard..... it would some time trigger the Bee-r so I disabled it.
Old Mar 5, 2019 | 11:09 PM
Javenp14's Avatar
Not sure if anyone is still on this. But does anyone know if it is possible to install this on a 1992 Nissan hardbody, na ka24e
amarSX
May 4, 2007 03:43 PM
mapleridge818
Aug 8, 2006 07:09 PM
luiswoohoo
Jan 17, 2006 08:31 AM
inspectorgadget
May 1, 2005 09:08 AM
Paully
Apr 2, 2004 01:37 AM
