electric fan install
1. get an electric fan(s)
be sure the fan(s) will meet your needs that is a "push" or "pull". mine are two ac condenser fans welded together. as long as the fan(s) you are not adjustable speed this will work for you. http://i122.photobucket.com/albums/o...1st/fans-1.jpg 2. find the relay(s) and temp switch if you are going to use one fan one relay is fine. for two fans you'll need two relays (1 per fan) you can buy a bosch spdt (single pull double throw) relay from just about any parts store for about $5. or you could get a used nissan headlight relay for about $2 at a wrecking yard. the temp switch is made my hayden inc. you can find them at any parts store for about $20 (3652 is the kit number) http://i122.photobucket.com/albums/o...topofrelay.jpg 3. mount the temp switch just find a suitable location and secure it. it only has two connections that need to be made the one marked "c" will be the +12v from the relay and the other will be the ground. the temp probe will need to be placed near the upper radiator hose. http://i122.photobucket.com/albums/o...tempswitch.jpg http://i122.photobucket.com/albums/o...fansground.jpg http://i122.photobucket.com/albums/o.../tempprobe.jpg 4. wiring the relay(s) 1. +12v from ignition (15amp)-here i used the ac wiring since i don't have ac 2. +12v to "c" on temp switch 3. +12v from battery (15amp) 4. not used 5. to + on fan(s) http://i122.photobucket.com/albums/o...2vignition.jpg http://i122.photobucket.com/albums/o...st/wireing.jpg http://i122.photobucket.com/albums/o...1st/relays.jpg http://i122.photobucket.com/albums/o...aysmounted.jpg http://i122.photobucket.com/albums/o...finished-1.jpg 5. try it out you should set the switch to the lowest setting and make sure the fan(s) turn on. if this is so turn the switch to the next setting. the fan(s) should turn off now and come on in a few minuets. if they do you did it right. if you have any questions just ask and i'll do my best to answer them. |
nice..
love the wire holding the vacuum hoses up....LOL.... must be better than that bulky clutch type fan.... |
Clean yo bay little girl!
thers wires EVERYWHERE haha, nice instal
hahaha, i think your the only 240 owner ive seen solder and heatshrink a wire. Man too many of us are cheap as hell.
Originally Posted by txsileighty
(Post 341926)
nice..
Originally Posted by Fries
(Post 341962)
uhhmm yeah ok. |
yeah my 89 looks like that, i dont know what the previous owner did, but wires and vacuum are over the place....
This info will come in handy when I wire up my fan for the install to come, good write-up.
thanks.
always glad i could help. |
If some one doesn't sticky this thread I am going to be pissed!!
Haha, awesome write-up. You know you're a true 240 owner when you have random wires holding stuff up. I love it! Lmao.
Originally Posted by BigVinnie
(Post 342134)
I'm surprised that nobody has mentioned the effects that removing the stock clutch fan has on the engine. Less drag on engine = better fuel economy (according to my tests)... however, less drag on engine = foot farther to the floor. =]
^^its common knowledge here bro
not very new.. but many people ask over and over good stuff. it doesn't need to be stickied.. its in the how-to section lol. remember you also got you altima fan install floating around vinnie |
(Post 345782)
