200psi compression help??
does anyone have any idea why my compression would look like this???
cold
#1 205
#2 195
#3 204
#4 125
after drivin
#1 205
#2 205
#3 205
#4 205
car details
1998 240sx ka24de
248/232 cams
drop in k&n
dual electric fans
full exhaust no cats
problems
exhaust cam is harder to turn manually then intake cam like waaay harder
cold
#1 205
#2 195
#3 204
#4 125
after drivin
#1 205
#2 205
#3 205
#4 205
car details
1998 240sx ka24de
248/232 cams
drop in k&n
dual electric fans
problems
im gonna say rings.
best way to test...
do it cold since thats when you get odd numbers. make sure that while youre cranking it over, you have the gas at WOT. on the low cylinders (#4) add a little bit of oil down the sparkplug hole, crank over a couple times, then retest. if the numbers go up significantly, then its your rings. if they go up a little bit, but arent even close to the other numbers, then its your valves.
best way to test...
240sxSleeper
Jul 7, 2005 01:24 PM
