5k rpm rev limiter in every gear!! help!!
Old Feb 24, 2006 | 10:50 PM
j0nathanl3e's Avatar
every time i go up to 5k rpm, theres a limiter that wont let me go beyond that point. it happens in every gear...the stock limiter is supposed to be only on 4th and 5th ( if im not mistaken)...but this is weird. earlier today, it was fine. this happened all of a sudden. during the whole day, it has been running fine and even now it's running good. so what could cause the limiter?
could resetting the ecu fix it??
Old Feb 25, 2006 | 09:39 PM
can anybody help? i tried searching, but i couldnt find the answer that i was looking for..
it's getting really annoying not being able to get all the rpms in each gear. it just abruptly stops at 5k. ineed help fellas
Old Feb 26, 2006 | 04:34 PM
anyone have any input??
can a vacuum leak cause this sort of thing?
Old Feb 26, 2006 | 06:13 PM
re037's Avatar
go ahead and try resetting the ecu. then read the diagnostic codes. besides, power dies after 5k and you want to take it easy on these old motors
Old Mar 5, 2006 | 09:20 PM
the limit is gone!! just all of a sudden it went away...but prior to that, i resetted the ecu, checked my 5th gear switch (it was fine), and started shifting at 2500ish. what a weird thing to happen..im just glas its gone now. thanks for the help fellas.
Old Mar 6, 2006 | 07:57 PM
Preston's Avatar
check your maf connector. If it's loose and not getting full signal it will cut out due to it not reading correctly. Happened to me once and I couldn't go past 3k.
EDIT: You fixed it, didn't show up at first. But I'll leave the info for anybody else who may need it.
Old Mar 6, 2006 | 08:35 PM
omg..it came back..
wow all of a sudden i started to get the limit again. all i did was run up the band a couple times just to feel it again. then like an hour later, its back. i just installed an intake so all the hoses are all in check. (aem gave me some sh**** hoses, one was cracked and they didnt fit right with my sensors) i guess ill just have to get it diagnosed or soemthing..
Old Mar 9, 2006 | 06:56 AM
Preston's Avatar
Reset the ECU again. When I did my custom intake I had to do it twice. Don't ask me why I have no idea. First time, ran like ****, reset again...big *** power increase and no problems.
Old Mar 9, 2006 | 01:40 PM
yea, ill do it again. what i noticed was when i drive really hard for a bit, the limit will come. then after that, if i start driving really soft, shifting at 2500 or so, itll go away in a little. its pretty bizarre...
Old Mar 9, 2006 | 04:52 PM
bennieb's Avatar
check intake tubing
Biggamehit
Apr 7, 2010 04:05 AM
rbs13secoupe
May 3, 2008 02:21 AM
crimsontide240
Dec 28, 2006 09:43 AM
Alias
Mar 6, 2002 04:10 PM
