5th gear
Old Jan 27, 2003 | 07:47 AM
<|2ice|3urner>'s Avatar
5th gear
when I'm driving on the highway in 5th gear, is it normal for the steering wheel to shake when my speed drops.
Old Jan 27, 2003 | 01:13 PM
I'm with Stupid's Avatar
No.
Old Jan 28, 2003 | 04:51 AM
Mightymouse's Avatar
What do you mean when your speed drops...
do you mean when you apply the brakes at high speeds?
or do you mean when you lift off the gas and coast to slower speeds?
things to consider:
- when you got your tires balanced, did the shop balance them on the outside AS WELL as the inside. Some shops only balance wheels on the inside, its better for both sides. The advantage is more stability over high speeds.
- if the wheel shakes while you apply the brakes... check your wear and tear on your pads and rotors.
- maybe the cable in your steering wheel has become loose.
Old Jan 28, 2003 | 08:00 AM
dkdeleon's Avatar
if it shakes bad when you apply the brake , check your tension rods also as said before get tire balanced
Old Jan 30, 2003 | 09:13 AM
jaltima's Avatar
True...your best bet are tires and rotors.....
CNDS14_240SX
Oct 25, 2004 02:59 PM
Nzo
West Coast/Hawaii
Sep 19, 2003 03:47 AM
skilo240
Apr 10, 2003 07:14 PM
Creamyitalian
Feb 4, 2003 08:18 PM
Ryan
West Coast/Hawaii
Oct 7, 2002 04:50 PM
