calling all kade specialist
ok so i just rebuilt my motor( crank, crank bearing rod bearings and rings) and everything is back together and the mother ****er wont turn over. when it was on the stand everything turned fine but when we were putting on the flywheel and clutch i noticed that it was a little difficult but nothing crazy so i didnt think anything about it. but now it wont move at all and i check to see if the drive shaft would spin and it does so i dont think it is the transmission and i dont know what the **** to think right now. so any help would be greatly appreciated.
I would PM BigVinnie, he's an NA KA guru. Him or Donnie (AKA Biggamehit) I trust them the most on this site. There are others I trust, but those two guys are always the first names to pop up in my head when it comes to KA issues.
so i doesn't turn in either direction at all? as you turn the crank there are times when it turns easily and takes more effort at other times. this is of course because the cams are forcing the valve springs down. it may sound like a stupid question but are you sure that this isn't the case?
also are you sure the timing is right on,assuming that the crank will turn but only to a point and then stop i would be lead to believe that a valve would be hit the piston.
Organizing the local forum with Teddy, Building up my 240sx, Working like a work aholic, moderating this forum, selling car parts on the side, and getting ready to go camping at stoney gorge this weekend...woot woot!!!
sorry me and my family went camping over my spring break and couldnt get to a computer but anyways the motor wont turn at all easily or hard it just wont turn at all and jared explain to me why the motor would turn when it was on the stand and i could understand get machine work done if my walls looked like yours and ill check the dizzy out and see if that is the problem. another thing we checked was the starter to make shure that it was in right and evry thing was hooked up properly and it was so i gues thats all that left to check.
