can someone help me?
I have a bad starter i tried replacing it but its way too hard i cant really get to it. i got 1 bolt off and the other 2 i couldn't get. what steps do i need to take in able to remove the starter what is the fastest way of replacing it. does the intake manfold have to come off or what??? i tried geting under the car and it was too much of a ***** cuz the tranny is there and ****. please help. thank you
Re: can someone help me?
All i did was jack the front end up (use jackstands and disconnect the negative battery terminal! Remember saftey third). First I removed the two connections on the front of the starter. One is like a 12mm bolt and the other one is a plug. I used a screwdriver to get the little catch on the plug out. After that, I used an extension and a u-joint, and had someone guide me from above the car to get the top bolt of the starter out (the one you cant see). The bottom on is simple, so i dont think i need to explain it.
kingcarm
Nov 1, 2003 02:56 PM
