code reader
does anyone know what code reader i would use for a 1993 240sx with a ka24de and where i can purchase such an iteam?????????????????????????
Just use the little knob on the ECU and count the number of times the light blinks
does that tell if it is obd 1 or 2 cause ive been doing some reserch and from what i can see niether will work
buy the consult tool from nissan, only a few thousand ^^
Originally posted by nazo78 does that tell if it is obd 1 or 2 cause ive been doing some reserch and from what i can see niether will work |
sort of im really trying to find out a reader so i can reset the check engine light and see what the thing is telling me.ive tried the whole disconect the battery thing but no luck.instead of resetting it i would like to know why its on. also does any one know the effect (pros and cons) of removing the engine fan. not the electric one. i live in a mild climate if that has any play on it. or do you recomend maybe a flex lite.thanks this is the greatest forum on earth.
That should help you with the ECU and getting the codes. If your car is 1993 it is OBDI, as for the fans, get some electric fans (flex-a-lite, Altima fans, Taurus SHO fans) and take off the engine fan.
thank you for your speedy response. very very helpfull.s13 240 i will try that with the fans. reo37 very helpful link. gonna try it.thank you
