code reader
Old Mar 19, 2006 | 06:14 PM
nazo78's Avatar
Lightbulb code reader
does anyone know what code reader i would use for a 1993 240sx with a ka24de and where i can purchase such an iteam?????????????????????????
Old Mar 20, 2006 | 02:10 AM
Just use the little **** on the ECU and count the number of times the light blinks
Old Mar 20, 2006 | 10:04 PM
nazo78's Avatar
does that tell if it is obd 1 or 2 cause ive been doing some reserch and from what i can see niether will work
Old Mar 20, 2006 | 11:14 PM
re037's Avatar
buy the consult tool from nissan, only a few thousand ^^
Old Mar 21, 2006 | 02:05 AM
So are you just trying to figure out if your car is OBDI or OBDII?
Old Mar 21, 2006 | 08:05 PM
nazo78's Avatar
sort of im really trying to find out a reader so i can reset the check engine light and see what the thing is telling me.ive tried the whole disconect the battery thing but no luck.instead of resetting it i would like to know why its on. also does any one know the effect (pros and cons) of removing the engine fan. not the electric one. i live in a mild climate if that has any play on it. or do you recomend maybe a flex lite.thanks this is the greatest forum on earth.
Old Mar 21, 2006 | 10:34 PM
re037's Avatar
http://www.**********/faq/articles/ecm_codes_doch.htm
*cough* =)
Old Mar 22, 2006 | 01:51 AM
That should help you with the ECU and getting the codes. If your car is 1993 it is OBDI, as for the fans, get some electric fans (flex-a-lite, Altima fans, Taurus SHO fans) and take off the engine fan.
Old Mar 22, 2006 | 06:24 PM
nazo78's Avatar
thank you for your speedy response. very very helpfull.s13 240 i will try that with the fans. reo37 very helpful link. gonna try it.thank you
240maxse
Oct 13, 2007 12:58 PM
Talde
Jun 25, 2007 12:42 PM
yiaracer
Apr 8, 2003 03:28 PM
Justin.b
Mar 20, 2003 06:45 AM
240SEX
Feb 25, 2003 02:05 PM
