compression test
Old Sep 28, 2003 | 08:26 PM
fastback240sx's Avatar
compression test
What should be the correct reading of a stock 89 240sx engine in a compression test.
Old Oct 4, 2003 | 01:56 AM
Juvenate°'s Avatar
Minimum is 142 psi. Standard is at 192 psi. Difference limit between cylinders should be no more than 14 psi. Hope this helps.
Old Oct 4, 2003 | 10:02 AM
is that a cold engine or hot?
Old Oct 4, 2003 | 10:52 AM
Juvenate°'s Avatar
Hot....FSM says to warm up the engine before testing compression.
Old Oct 4, 2003 | 08:25 PM
drnovascotia's Avatar
most definately have your engine at normal running temperature when testing to have most accurate results. Not after a long ride or just after you turned it on.
Dr.
epoxy
Feb 23, 2004 09:28 PM
Sil80guy
Feb 20, 2004 11:52 AM
240baja
Feb 16, 2003 01:19 PM
agressiveracing
Northeast
Oct 30, 2002 09:27 AM
