could this be the problem?
Old Feb 1, 2004 | 10:19 AM
NcTwOfOuRtY's Avatar
Question could this be the problem?
well we just discovered we had a leak in our injectors, and my car also has that taching out at 4-1/2 rpm problem, could ht eleaking injectors cause air to get in the system and set off a sensor somewhere and cause the ecu to go into safe mode? just wondering before I go through the hassle of replacing other things that dont need to be replaced, im going to fix the injectors ofcourse but i was just wondering if that could be causing that as well
Old Feb 1, 2004 | 10:48 AM
drnovascotia's Avatar
absolutly correct, injectors messing up can cause this problem you are having. because it's not getting the right amount of fuel, it's making sure not to blow her. Replace them & reset the ecu and you should be set.
Dr.
Old Feb 1, 2004 | 08:10 PM
woohoo i sure hope so im tired of just when i get it slidewayz startin to tach out ordered new injector seals and gonna take the injectors somewhere to get cleaned.
Old Feb 1, 2004 | 08:54 PM
Baloo's Avatar
i had a leak on my injectors it it caused my spark plugs to go bye bye so i would suggest checking your spark plugs aswell
Old Feb 3, 2004 | 04:19 PM
ok will do thanks for the advice! but we just replaced those when i got the car runnin (somewhat) like a month ago but I'll check to make sure
uvamosk
Aug 12, 2005 07:31 PM
leiferik1
Aug 29, 2002 06:20 PM
Daunttless
Feb 25, 2002 11:20 PM
Biohamhock
Feb 14, 2002 01:05 AM
Ben
Feb 10, 2002 09:27 AM
