Crank - No Start/rough Start
Old Sep 25, 2006 | 02:11 PM
KAMAKAZI 13's Avatar
Question Crank - No Start/rough Start
Hey guys, roger here.
i just changed my water pump yesturday everything went good. then i went to start it. it cranked but wouldn't start. then my friend point at something that wasn't connected. -_- forget the name. so i connected it and went to start again, cranked, started, then shut off a few seconds later. hmmm, interesting at this point. started it again, gave it some gas, a puff of white smoke came out, then idled fine. drove her around the block to make sure everything was good then back in my drive way. left her there for about 30 min. changed to grab something to eat. started it and did the same thing again, shut off a few seconds later. started it again, gave it some gas and idled fine... again. my friend noticed some white smoke again. he drove behind so he could see if anymore white smoke would come out, but nothing, no somke.
this morning i had class so i start her up fine but idle in the first few seconds jumped a bit between 800-1000 then was fine. after class i walked to the parking lot and started her up. crank but no start. did it again, crank but no start. third time cranked started a bit, gave it some gas then idled fine again. very odd at this point. didn't notice smoke at this point.
i am concerned as to what coul d be causing this crank - no start/rough start problem of mine.
any help would be mucho appreciated.
Old Sep 25, 2006 | 06:51 PM
sounds like it could be a vaccuum problem or electrical, are you sure everything is hooked up correctly? any loss of power once it is running?
Old Sep 25, 2006 | 09:58 PM
everything is connected correctly. i will check over vaccum lines again.
if anything it feels like i have better response. lo.
Old Sep 29, 2006 | 03:40 PM
greenbastard's Avatar
fuel pump could be pootched
Old Sep 29, 2006 | 05:07 PM
my friend told me that it could be the thermostat.
also something about cleaning the MAF?
not sure tho. =\
Old Sep 29, 2006 | 11:44 PM
she did it again. after i got into work and got out like about 4 hours. the engine is cold of course. i started her up and just wouldn't start. crank but no start. then i tried it again. crank but no start then i gased a lot brought it up to 4k for about 5 seconds and it was fine.
this is really starting to bother me. i am worried and would like to get this problem fixed as soon as possible. i need more help guys please.
like i mentioned in my reply eariler ^ could it be thermostat like my friend said. if it is then should i just replace it with an OEM or NISMO thermo? anything about cleaning the MAF also? if so how would i go about doing this?
(still a noob here)
thanks guys.
Old Sep 30, 2006 | 03:57 AM
re037's Avatar
id check oil, plugs, wires, dist, ignition coil
Old Sep 30, 2006 | 02:59 PM
****ING S***!!!
crank but no start now. only if i pump the gas then it'll start. *sigh*
tear tear**
Old Oct 1, 2006 | 01:58 PM
will a stuck thermostat be cause of this in any way?
Old Oct 1, 2006 | 03:43 PM
re037's Avatar
nope. but im thinking fuel pump now too
Old Oct 1, 2006 | 06:07 PM
would that also explain the white smoke?
also is this going to cost me an arm and a leg?
RMS13FU's Avatar
it isn't your thermostat...
If it ran good before the water pump, and now you are having problems, I'm willing to bet you didn't hook up something correctly on the reinstall.
Look in the Factory Service Manual for Cold Start problems, it will be in the EC section.
Old Oct 1, 2006 | 07:06 PM
well it was bogging before the water pump before but it would start.
so that may have been the starting of what is happening to it right now.
Old Oct 2, 2006 | 08:34 AM
RMS13FU's Avatar
Check the FSM
Check your fuel pressure as well.
Old Oct 22, 2006 | 08:26 PM
positron's Avatar
I had a problem like this on my first 240. This was before I started working on cars myself so I took it to a dealership for repair. They said I had a clogged fuel line.
