driving open headers, does it give more hp or lose some torque?
i was thinkin of racing open headers at the track, but i wasent sure if the car would lose some hp/ trq or gain some.
i need suggestions please. |
It loses tq, at least thats what it felt like to me. It seemed like throttle response went to **** also.
im not really sure, are you na? i dont think youll loose anything. i know on bigger exhaust systems on n/a youll loose alittle bit of torque but thats because the pipe is bigger and the exhast gases are in a confined space, then you run into "scavenging" and stuff. since the exhaust gases arent in a confined space without an exhaust, scavenging doesnt play a part? im not really sure though about running no exhaust. mabey i was right or on track or sounded like an idot, lol. hope that helped. someone corect me if im wrong, id like to know too:D
I am assuming he is N/A since he is talking about headers and not a downpipe.
yes, my car is na. and i have a 3in exhaust
im sure you would probally lose some tourqe seemings you loose it as you go to a bigger exhasut. probally gain some top end though...either way its uneccesary.
yea pretty much unecessary, your 3in. exhaust has already killed your poor ka's torque levels and the minimal amount of topend you have gained will not be increased anymore by running open headers, save yourself some time and just run it how it is, you be better off doing minor weight redux if your really trying to drop your times as much as possible, although they wont go down a whole lot from the 50lbs max your going to remove..
Originally posted by KerosineK I am assuming he is N/A since he is talking about headers and not a downpipe. |
Open header is stupid for a street car and you need to tune for open ehader if you wanna use it at the track.
wat if i run with just headers, downpipe and catalytic converter. no catback? would i still lose hp?
n other question, how come i would lose torque if im lettin the engine breath better with a bigger exhaust or not exhaust? |
there isnt in backpressure.
n other question, how come i would lose torque if im lettin the engine breath better with a bigger exhaust or not exhaust? [/B][/QUOTE]
because of scavenging. when exhaust gases leave the exhaust port they pull the gases behind them out. if you have a bigger pipe the exhaust gases have to expand to the size of the pipe, then pull the gases behind them resulting in less exhaust gas coming out before the valve closes because time was lost from expandiing. bigger than stock is better but you can only go so big before you start losing power. most bigger pipes losse torque but gain you a little top end, too big will loose both tq an hp. i think that was right. |
so basically runnin open headers, not cat-back or with 3in, i still lose trq. damn!! i just wanted to make my car louder at the track. but i guess not.
thanks for advices all of u. |
Pfft. Ricer..... Have you ever driven a car (namely a 240) with open headers? It is way too loud. At 2k RPM, I couldnt hear what my passenger was saying right next to me. Your best bet is to just stick with a catback exhaust and maybe look into a test pipe.
why are you trying to make your car louder for the track? trying to attimidate your opponents? thats dumb.
