Electrical Problem
Old Jul 28, 2005 | 04:52 PM
AndyZ's Avatar
Electrical Problem
Ok there is this old guy by my house selling a 240 for pretty cheap and I am thinking about buying it, however he says it has a strange "unknown" electrical problem.
He says that the car will drain a brand new battery in three days...but that sounds simple right? the alternator.
BUT!! he says he had the alternator removed and tested and supposedly it works just fine but the car will still drain batteries..
Is there any other way something like this could happen? is it an easy fix or not?
Any help would be greatly appreciated
Old Jul 29, 2005 | 01:59 PM
daves240sx07's Avatar
I believe there is a current draw at all times. You will have to hook up a meter to read the draw. If draw is present then start by pulling one fuse at a time. You have to know what the fuses run also. If the fused is pulled and the draw stops this will at least narrow your search on the problem. Make sure the key is off and doors closed. Make sure all lights are turned off inside and out. If you do not know how to hook up a meter to read current draw maybe someone you know, know's. It makes it easer to find.Hope this helps.
Old Jul 29, 2005 | 02:02 PM
I should of ask this first. Does the battery die after sitting for three days or does he drive it and it dies after three days?
Old Jul 29, 2005 | 02:49 PM
AndyZ's Avatar
He says that even when its just sitting it still drains the battery
Old Jul 31, 2005 | 12:33 PM
Do a current draw test with a meter.
Old Jul 31, 2005 | 02:01 PM
Juiced240's Avatar
Somethings grounding out, or not shutting off like it should. I would make sure when they did a bench test on the altenator they load tested it. I had some moron do that to me at some place. Argued with him for a few minutes then left. Went to autozone and someone with half a brain tested it and sure enough it was bad.
uvamosk
Aug 12, 2005 07:31 PM
shaughn
Jul 28, 2004 07:41 AM
war
Jun 19, 2004 07:02 PM
kaos
Jan 14, 2004 01:38 PM
s240r
Aug 13, 2003 03:29 PM
