Engine light....
Does the engine light on the dash come on whenever it reads a code on the ecu? or is the light there for main things like oil pressure, temp, etc?
Re: Engine light....
Originally posted by NismoKa Does the engine light on the dash come on whenever it reads a code on the ecu? or is the light there for main things like oil pressure, temp, etc? |
Most of the time the computer turns on the CEL when it has a code. Certain codes do not turn on the CEL. If the bulb is burnt out, then it will of course not turn on, even if there is a code. Low oil pressure, high coolant temperature, low brake fluid level/parking brake and battery each have their own lights.
