Engine light....
Old Oct 22, 2004 | 05:35 PM
NismoKa's Avatar
Engine light....
Does the engine light on the dash come on whenever it reads a code on the ecu? or is the light there for main things like oil pressure, temp, etc?
Old Oct 23, 2004 | 10:37 AM
Re: Engine light....
Naw, ECU can be holding a trouble code in it without the "check engine" light going on (at least, in my car it didn't go on).
Old Oct 25, 2004 | 10:48 PM
devnull's Avatar
Most of the time the computer turns on the CEL when it has a code. Certain codes do not turn on the CEL. If the bulb is burnt out, then it will of course not turn on, even if there is a code. Low oil pressure, high coolant temperature, low brake fluid level/parking brake and battery each have their own lights.
craigkiel
Mar 6, 2004 09:43 PM
s14.5boy
Dec 14, 2003 04:15 AM
neolikquidx
Oct 16, 2003 10:08 PM
neolikquidx
Oct 15, 2003 12:18 AM
neolikquidx
Jun 16, 2003 08:44 PM
