fuel presure
Old May 14, 2009 | 05:02 PM
deputydawg's Avatar
fuel presure
can anybody please tell me what the proper ammount of fuel preasure needed for a stock ka24de??
Old May 14, 2009 | 10:07 PM
43psi
Old May 14, 2009 | 11:19 PM
240-kid's Avatar
34psi actually (Idle), 43psi at WOT or when Vacuum isnt present...
Old May 14, 2009 | 11:43 PM
actually, it's 33psi when the vacuum hose is connected and 43psi when it's disconnected. at wot it's much higher.
Old May 15, 2009 | 04:05 AM
^^ +1
Old May 17, 2009 | 08:15 AM
BigVinnie's Avatar
All fuel pressure on all nissan fuel rails with regulators at stock idle is 34.5 PSIG at idle.
This means when you test the pressure it should be at 33.8 ~ 34.5 PSIG any lower and any higher you have a bad regulator. Now using stock 270cc injectors the fuel pressure should rise to almost 47~49? PSIG at the fuel rail during WOT and an rpm of about 5800RPM. This number drops if you use larger cc injectors such as sr20det 370cc injectors, that's why it's important to swap out to a larger pump that can handle that injector pulse width.
When you install a q45 fuel pump on a 240sx fuel tank without the Q45 relay, or a 350z pump, and you use the stock fuel rail and regulator static PSIG becomes 46.3 PSIG at idle.
I believe the same thing happens when you use a walbro pump, but I havent checked that myself to make sure its valid.
The higher fuel pressure at 46.3 PSIG is better if you use E85 on your engine, or if you are turbo charged with gasoline.
I believe Jecs injectors are only meant to handle 50 PSI, but people have been know to run them notoriously higher like in the high 85PSI range.
Old May 17, 2009 | 09:03 AM
ha yea good info vinne.. for my ka-t setup i only used the stock FPR with vac.... i was only running 8 psi... and the FPR is the same as the SR etc.
Old May 17, 2009 | 04:49 PM
BigVinnie's Avatar
Some people don't realize that the JDM silvia, and the USDM 240sx use the same fuel pump. What most sr guy's don't understand is that somewhere around the 9 PSI (T25) range the fuel pump starts to burn up. I would recommend upgrading to a larger fuel pump for use with E85 and turbo charging because of that reason.
I mean in most circumstances if some one was to upgrade to a larger turbowith a a/r higher than .65, i would defenitely upgrade the fuel pump, since the injectors would demand more fuel at less PSI.
Old May 22, 2009 | 03:23 PM
yeaup..... those same people don't believe we evolve from monkies also lol
RNN14
May 18, 2002 12:49 AM
RNN14
May 9, 2002 04:32 AM
RNN14
Feb 28, 2002 01:33 PM
Black97240sx
Feb 20, 2002 09:10 PM
Dom
Feb 10, 2002 12:03 AM
