Gas Leak, Need help fast....or booM!
Theres a gas line that runs over the top of the skid plate i guess you can call it, theres a valve with a clamp on it, well at least mine does, the hose is leaking were it meets the valve, either its coming off or its loosend for some reason, what can I do to fix this. I tried pulling the hose forward and reclamping but it didnt work, is there any kind of non flampable semi permanent apoxy or insulation that i can run on the hose to the valve?
replace it. either new part or out of junkyard, but dont, please dont, try to epoxy or glue on gasoline fittings!
thanks!
ur welcome ;).......but did you get it fixed?
