Gas Leak, Need help fast....or booM!
Theres a gas line that runs over the top of the skid plate i guess you can call it, theres a valve with a clamp on it, well at least mine does, the hose is leaking were it meets the valve, either its coming off or its loosend for some reason, what can I do to fix this. I tried pulling the hose forward and reclamping but it didnt work, is there any kind of non flampable semi permanent apoxy or insulation that i can run on the hose to the valve?
slidewithpride
Aug 12, 2011 09:51 AM
.......but did you get it fixed?
