head gasket swap...hints??
Old Nov 6, 2002 | 11:23 AM
konseiEva's Avatar
I'm replacing the head gasket on an 89 ka24e this weekend, does anyone have any suggestions that will make the procedure easier? or any suggestions on additional maintenance i should do at the same time?
Old Nov 6, 2002 | 03:51 PM
Import Fanatix's Avatar
Well while your taking apart the engine, I would replace the piston rings and valve seals and that adds like another 100K to your motor. This way you don't get any oil blow by. That is my advice.
Old Nov 6, 2002 | 06:20 PM
konseiEva's Avatar
nice thanks
any idea around how much time that will add to labor.
we thought we could do the head gasket, spark plugs, spark plug seals, valve cover gasket, and flush the cooling system in about 5 hours, oh and throw in a rebuilt head if needed. probably gonna increase timing by 2degrees too. and look around to see if there's anything else that could be done while in there.
that's the plan...and get it done to go to a party sat nite we'll see how it goes
Old Nov 7, 2002 | 09:01 AM
konseiEva's Avatar
bump
Old Nov 7, 2002 | 09:23 AM
konseiEva's Avatar
bump
Old Nov 7, 2002 | 11:23 AM
well i think that it might add some extra time to the job, not know exactly how much in reality, but with all that plus the rings and valve seals you'll engine be almost completely brand new and would be needed to be broken in again like it was when the car had its original owner. 1000 miles under 3.5K and under 55 mph.
But time wise I don't really have a guesstimate but that it would be some added time
Old Nov 7, 2002 | 06:05 PM
I'm with Stupid's Avatar
Piston rings and valve seals is A LOT of work. You'd be better off just replacing the engine than doing that much work. BTW I don't think you'd have to break it in again if you did that anyway, break in periods are for any metal particals in the engine and so the bearings get set in. If you had it machined then you'd have a break in period ,but not for that stuff.
Old Nov 7, 2002 | 06:58 PM
konseiEva's Avatar
i am NOT replacing the engine unless its an upgrade...this is just ****e to get it running and decently while doing some extra junk while i'm in there
well i'm taking the head to a machine shop to get cleaned and checked. they'll rebuild it for me if needed for $150 plus any parts needed. that would take care of the valve seals though.
Old Nov 7, 2002 | 08:26 PM
spitz7985's Avatar
5 hours? maybe if you're superman.
Old Nov 8, 2002 | 12:38 AM
konseiEva's Avatar
superman?? naw i'm she-ra
Old Nov 8, 2002 | 01:20 PM
spitz7985's Avatar
it's all coming together
Old Nov 8, 2002 | 10:27 PM
When you break in an engine, your breaking in the piston rings and nothing really else. Thats why you break it in, so therefore if you replace the rings you break them back in.
Old Nov 9, 2002 | 02:23 PM
No, that's not true.
70Challenger
Jun 25, 2006 02:28 PM
89180sx
Jul 15, 2003 01:57 PM
Monkey Force
May 31, 2003 01:00 AM
roadkill669
Apr 9, 2003 07:18 AM
bazan
Jan 11, 2003 12:37 PM
