help with ignition, please! already searched
my 92 de won't start... I already changed the spark plugs, wires, disto cap, rotor and ignition coil. Checked ignition switch fuse, still good. What can it be???
It first started when i was driving home from somewhere and i notice while i was driving my car stopped accelerating. Then i kept on pressing on the gas pedel and it started accelerating again. After 5 min... my car shut off, and it won't start anymore. I checked my ecu for codes and i got a code 21, which is: ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning. |
i dont know if these cars have them or not, but that sounds liek a Crank position sensor, or a camshaft position sensor..... unless the computer has its own specific codes for those.... then i dunno.
I checked my ecu for codes again after installing those parts i listed on this topic. And I came up with code 11, which is camshaft position sensor. Where is it located at?
just to be thorough, did you check your starter/ starter relay?
I just fixed the problem! It was the harness that plugs into the ignition coil. The harness was all cut up from the previous owner. Thanks for the replys guys:thumb:
