help with ignition, please! already searched
Old Oct 31, 2005 | 08:51 PM
mirakulist's Avatar
my 92 de won't start... I already changed the spark plugs, wires, disto cap, rotor and ignition coil. Checked ignition switch fuse, still good. What can it be???
It first started when i was driving home from somewhere and i notice while i was driving my car stopped accelerating. Then i kept on pressing on the gas pedel and it started accelerating again. After 5 min... my car shut off, and it won't start anymore. I checked my ecu for codes and i got a code 21, which is:
ignition signal in the primary circuit is not being entered to the ECU during cranking or tuning.
Old Nov 1, 2005 | 05:21 AM
Roastem's Avatar
i dont know if these cars have them or not, but that sounds liek a Crank position sensor, or a camshaft position sensor..... unless the computer has its own specific codes for those.... then i dunno.
Old Nov 1, 2005 | 10:19 AM
mirakulist's Avatar
I checked my ecu for codes again after installing those parts i listed on this topic. And I came up with code 11, which is camshaft position sensor. Where is it located at?
Old Nov 5, 2005 | 02:59 PM
just to be thorough, did you check your starter/ starter relay?
Old Nov 5, 2005 | 03:45 PM
mirakulist's Avatar
I just fixed the problem! It was the harness that plugs into the ignition coil. The harness was all cut up from the previous owner. Thanks for the replys guys
modest180sx
Mar 26, 2007 10:40 PM
240m3srt
Oct 4, 2006 11:26 PM
tuscani451
West Coast/Hawaii
Aug 8, 2005 09:13 PM
needa240
Feb 6, 2005 12:15 PM
emericanchaos
Jan 19, 2004 10:31 PM
