help ka24de
Old Feb 22, 2004 | 12:52 PM
laurieandmike's Avatar
help ka24de
hi again
ok i went to check the valves clearences today and when i put the engine on tdc i noticed the cam chain is not on its marks again so i turned it over to see if it was off 360 but still no line up
what could cause this?
i think this is wha is causing my knock lol there is alot of clearence between all valves when it is like that
the chain is tight though
i dont understand
please help
mike
Old Feb 28, 2004 | 10:41 AM
dkdeleon's Avatar
Its not what is causing your knock you have to turn it several times to line up the top chain. what kind of knock are you getting?
I had the same problem and I to thought it was a lifter but it was'nt . It was that my oil pan had gotten dented up far enough to stop the oil from getting to the rod bering and I was lucky not to spin a bering, I pulled the pan and changed the berings then beat the oil pan back in to shape and viola no more knocking. hope this helps.
240sxka24
Apr 21, 2006 10:11 AM
Purple240
Mar 18, 2006 01:31 AM
YangpaNemsay
Jul 20, 2004 01:35 PM
cheap240
Oct 15, 2003 09:51 PM
leiferik1
Oct 13, 2002 08:45 PM
