hesitation
i have a 1990 240sx sohc ka24e , in 1st 2nd 3rd and 4th sometimes 5th my car hesitates to accelerate i feel this violent jerk too , me and my dad replaced the cap rotor plugs and wire, but it still didnt go away, i have no idea what it is and also my car is loosing fuel, because my mom drives her crown vic more than me and she has a v8(92 model 5.0) and i waste more gas than her , someone plus help. thank you
Check for any vacuum leaks,check ur 02 sensor!,Check for a faulty throttle position sensor ,do a complete fuel system clean up and check for any sensor or part that works in conjuction with ur emissions ,after that let me know how it works !,btw make sure ur fuel pump is in good condition and not faulty.
hey bro thanks, i was told by a friend that maybe my fuel filter might need to be changed?
All righty ,let us know if u still have the problem!
on the 240 where is the fuel filter, i plan to do this tomorrow
Originally posted by fast240 on the 240 where is the fuel filter, i plan to do this tomorrow |
i installed it and i got to thinking cos its dbl in size you sure it wouldnt hurt anything
Originally posted by fast240 i installed it and i got to thinking cos its dbl in size you sure it wouldnt hurt anything |
it just makes your throttle response better it doesnt give you more power but the tt filters are cheaper than the 240 ones so its worth it. i have one on mine it doesnt hurt anything. if it still does it, could it be your clutch slipping? but you still shouldnt be wasting so much gas. check for gas leaks and also check for any crack in you intake/manifold. if you find the problem let me know.
read a thread somewhat similar to this one and then a couple of days ago it happened to my car. It hesitated on 2nd & 3rd. It only did it twice that day so it was weird. Let me know how it goes and I'll do the same.
Get a tune-up. If it was the fuel filter the car wouldnt be using alot of gas. I did a tune-up on my KA when I got it for this reason and didnt have a problem until the day I did the swap. Usually with a bad fuel filter your car will hesitate at higher rpm's. Not through the lower rpm's. I would say it's something more along the lines of valves and timing.:thumb:
