hesitation
Old Dec 26, 2004 | 08:14 PM
fast240's Avatar
hesitation
i have a 1990 240sx sohc ka24e , in 1st 2nd 3rd and 4th sometimes 5th my car hesitates to accelerate i feel this violent jerk too , me and my dad replaced the cap rotor plugs and wire, but it still didnt go away, i have no idea what it is and also my car is loosing fuel, because my mom drives her crown vic more than me and she has a v8(92 model 5.0) and i waste more gas than her , someone plus help. thank you
Old Dec 26, 2004 | 09:01 PM
rivneo1's Avatar
Lightbulb
Check for any vacuum leaks,check ur 02 sensor!,Check for a faulty throttle position sensor ,do a complete fuel system clean up and check for any sensor or part that works in conjuction with ur emissions ,after that let me know how it works !,btw make sure ur fuel pump is in good condition and not faulty.
Old Dec 27, 2004 | 09:06 AM
fast240's Avatar
hey bro thanks, i was told by a friend that maybe my fuel filter might need to be changed?
Old Dec 27, 2004 | 09:12 AM
rivneo1's Avatar
All righty ,let us know if u still have the problem!
Old Dec 28, 2004 | 07:49 PM
fast240's Avatar
on the 240 where is the fuel filter, i plan to do this tomorrow
Old Dec 28, 2004 | 08:04 PM
rivneo1's Avatar
Its on ur passanger fender site of the car ,look down underneath the intake manifold it should be around that area and get urself a 300ZX TT fuel filter is bigger so it doesnt hurt having better filtration .
Old Jan 5, 2005 | 07:43 PM
fast240's Avatar
i installed it and i got to thinking cos its dbl in size you sure it wouldnt hurt anything
Old Jan 5, 2005 | 08:22 PM
rivneo1's Avatar
No it wont its considered to be a cheap upgrade,provides more fuel filtration and fuel flow should be about the same or better.
Old Jan 6, 2005 | 11:00 AM
s13_peacekeeper's Avatar
it just makes your throttle response better it doesnt give you more power but the tt filters are cheaper than the 240 ones so its worth it. i have one on mine it doesnt hurt anything. if it still does it, could it be your clutch slipping? but you still shouldnt be wasting so much gas. check for gas leaks and also check for any crack in you intake/manifold. if you find the problem let me know.
Old Jan 8, 2005 | 05:20 AM
naptime's Avatar
read a thread somewhat similar to this one and then a couple of days ago it happened to my car. It hesitated on 2nd & 3rd. It only did it twice that day so it was weird. Let me know how it goes and I'll do the same.
Old Jan 8, 2005 | 06:01 AM
TWAN's Avatar
Get a tune-up. If it was the fuel filter the car wouldnt be using alot of gas. I did a tune-up on my KA when I got it for this reason and didnt have a problem until the day I did the swap. Usually with a bad fuel filter your car will hesitate at higher rpm's. Not through the lower rpm's. I would say it's something more along the lines of valves and timing.
osal1989
Dec 8, 2007 01:53 AM
JDMxDrift
Feb 5, 2006 11:57 PM
mapleridge818
Sep 4, 2005 02:32 AM
240-Silvia-240
May 8, 2005 10:41 AM
onesloweg5
Feb 21, 2005 02:17 PM
