How to replace coil with a performance coil.
Hey guys does any1 know how to install a new aftermarket coil to a ka24e, Its coil packets right?? I want a new aftermarket coil after I rebuild the engine which will be alot later seeing as my 240 past the 100,000 Mile mark and I think it time it gets something overhuald well at lest new Piston rings and send the Head to the machine shop.
Please some1 help me out? Oh and how much compression should my engine make?? like 175 right??:ugh: |
Moved to NA
KAs are distributor, not coilpacked Around 170 is a good compression on a hot engine. |
The coil is between the AIV and the Air filter box. I replaced it with an MSD coil. From experience the coil doesn't make a difference unless you have the msd box to go with it. MSD has two kinds of coils you can use. a box shaped one and a cylinder shaped one(I forget the names). The box one is recommended because of voltage but You will have to get a special coil wire to make it work.
The cylinder one(I used this) I believe it's called a blaster 2 works good for me, and I have an MSD 6A box. You will have to get the bracket for the coil and drill a couple holes to hold it. Also cut the two that were going to the coil and connect them to the new coil. There is a positive and negative so more research. Also it's not worth the work unless you get the MSD box to go with.[IMG]D:\Extra\CAR\TensionRod\msd.jpg[/IMG] |
first of all... img links from your computer dont work like taht, your supposed to upload them.. and second hyjynx you can get a coil system for the 240 but its like... 2.4k+installation and programing, and it turns the ka24de into a fully programable motor
LINK!!! http://attila.sdsu.edu/~mmikse/domai...ctromotive.htm you can get all the info there |
Originally posted by irax first of all... img links from your computer dont work like taht, your supposed to upload them.. and second hyjynx you can get a coil system for the 240 but its like... 2.4k+installation and programing, and it turns the ka24de into a fully programable motor LINK!!! http://attila.sdsu.edu/~mmikse/domai...ctromotive.htm you can get all the info there |
yeah if it was some old news i would of been like.. SEARCH... but since its new to me i figure not alot of people would know, btw they use it the the www.ka24de.com 's 400hp turbo s13
I forgot about the pic.
I thought he only wanted to change the coil. The TEC is a whole other monster. The MSD coil is like $40 and the MSD 6AL i think is about $100, You also need a tach adapter for like $20 or your tachometer doesn't work. Now what's the total on that $160 vs. $2,400 It's a big difference. It gives you some power. |
