I Need Help
Old Nov 25, 2005 | 11:10 PM
xXx's Avatar
xXx
Unhappy I Need Help
I have a knocking on the motor, do you know how to fix it.
I Have a KA24DE
Old Nov 26, 2005 | 01:25 AM
dkdeleon's Avatar
does it knock all the time or just when you
push the gas? does it get louder as the gears change? it could be your rod bearings but untill you explane more im just guessing
Old Nov 26, 2005 | 08:48 AM
xXx's Avatar
xXx
It knocks all the time, and when you press the gas it gets a little louder and it knocks faster
Old Nov 26, 2005 | 12:28 PM
dkdeleon's Avatar
I hope not but it could be a rod...
but I think its a rod bearing wich is easy to replace. drain oil remove oil pan and replace each rod bearing .
Old Jan 26, 2006 | 09:18 AM
im4streetracing's Avatar
FYI-afterwards get a new oil pan gasket too
Old Jan 26, 2006 | 10:27 PM
lukass's Avatar
How can you tell if it is a rod or just the bearing?
Will you be able to tell when the oil pan and the gasket comes off by looking at the bearings? Or do you have to put everything back together and fire it up and see what happens?
Jovan
May 30, 2006 03:58 PM
pck3
Apr 25, 2006 12:51 PM
PROJECT_D
Dec 11, 2003 06:11 PM
cheap240
Oct 15, 2003 09:51 PM
RedStage
May 30, 2003 01:13 AM
