IACV problem
Old Mar 9, 2005 | 05:43 PM
xedendau's Avatar
IACV problem
First of all- I searched. I've looked on every nissan forum I know of and cannot find the info I need. I'm new to this forum, but not a noob! About a week ago my car started having idling problems. I would start it and it would shut off, and would do this repeatedly unless I got on the throttle a little to keep it running. After a few seconds, when the motor warmed up a little, it idled fine. I did some searching online and decided to clean out my IACV. I cleaned it out with throttle body cleaner, put it back on, and now the car idles MUCH worse. I tried the adjusting screw but it didn't help. Before it idled when it was warm, now it barely idles. I adjusted the idle via the nuts on the throttle cable quadrant and now the car idles high enough to drive, but it's nowhere near smooth. It idles like it has a HUGE cam in it. Any suggestions? I'm in a bit of a situation here and need to get this fixed ASAP. Thanks!
Old Mar 13, 2005 | 04:40 AM
wikd240's Avatar
check for air leaks in the iacv...make sure you got al of your vaccume lines hooked back up... the search them all for cracks or dry rot... sounds like a vaccume leak problem to me... and when you went messing with things it made the problem worse... my vaccume line from my egr valve was dry rotted and it took me forever to find it... but that fixed the first of my problems...
sr91240
Feb 11, 2007 08:02 PM
ka-tfresh
Sep 5, 2006 01:17 PM
PhopsonNY
Apr 14, 2006 09:15 AM
Tanshin
Feb 6, 2005 08:32 AM
NiNJA323
Jan 18, 2005 08:07 AM
