im getting tired of this crap...
Old Dec 5, 2005 | 08:35 PM
Razo-E's Avatar
okay, my tach keeps bouncing from around 300 up to 1200 at stop lights (or when i dont have my foot on the gas and im going relatively slow), MAINLY when it's warmed up already..
sometimes it does it when the car's cold *recently*
im tired of it, and i have to step HARD on the brake pedal and give it gas, until it stays steady at 1000 rpms...
or course, sometimes it bounces anyway, and the car shakes BAD when the tach bounces as well...
im also wasting gas like a mother f-cker...
WHAT CAN THE PROBLEM BE..?!?
im guessing timing, cause im running super rich, and it only does this at low RPMs...
of course, why would it do it mainly when the car's warmed up..?
anyone else with this problem..?
it's turned off on me before, so i dont know how much longer it'll last...
Old Dec 5, 2005 | 11:11 PM
JoxteR's Avatar
mines not running rich but when my car was at idle it would fluctuate from like 400 to 1200 and die every now and again, all i did was unplug the maf plug in, then plug it back in, and it was fine after that, its done it a few times since and i just do the same thing to fix it. maybe try that if you havnt already.
Old Dec 6, 2005 | 12:24 AM
Razo-E's Avatar
well, im burning gas at a stupidly high rate, but that might not be related..
saying i should just unplug my MAF, and just plug it back in..?
how long does it last before you do it again..?
maybe i should clean it, too...
thanks
Old Dec 6, 2005 | 04:08 AM
Roastem's Avatar
I have seen the o2 sensor cause this...
Old Dec 6, 2005 | 01:48 PM
LA_phantom_240's Avatar
Yeah i would say that it will either be teh o2 sensor, or a faulty MAF sensor or a loose connection. It wouldnt hurt to check your timing and check your igniton system for any deficiencies
Old Dec 6, 2005 | 02:09 PM
iwannanSC's Avatar
My friend's 240 has the same problem. Sometimes it starts and runs fine, and sometimes it bounces around, can't find idle, and I have to keep my foot on the gas to keep it from dying. Also, if coming to a stop quickly from 75 or so, the car shuts off every time (assuming my foot is not on the gas).
Guess I'm in for some fun.
Old Dec 6, 2005 | 04:17 PM
Baloo's Avatar
yeah mine too i mean sometimes mine gets up to 2 grand and im like shyt....but then it slowly goes down....idk i think its a 240 thang my boys cars have done that too
Old Dec 6, 2005 | 05:30 PM
God's Avatar
God
ditto. same thing here
Old Dec 6, 2005 | 08:02 PM
Razo-E's Avatar
okay, it was a loose connection, it was a plug near the intake manifold..
my dad's friend (work at home mechanic) just pushed the connector together, and it's been fine since..
the gas thing still puzzles me, though..
Old Dec 6, 2005 | 08:03 PM
xXsilviaXx's Avatar
actually for me when i start it up in the cold it bounces from 800-1200 and once it's warmed up it stays at a steady 800 i'm glad this is a normal thing.
Old Dec 7, 2005 | 07:54 AM
Joel SX's Avatar
Its a normal thing for the cars to rev up when cold. Its the computer that does this to warm up the car. Also if you stop at a light and the car start to act up, like its goes down on revs and goes up again and down and up, like its jumping, then it might be a vacum leak. When the engine its a low revs, the vacum really matters b/c there's so litle air that any extra air into the A to F mixture its gona make big diferencem, so the car atcs up. Check all the lines going fro mthe MAF to the Engien manifold and other lines going out or into the manifold. My car had thsi problem for 5 months before I heard the "SSSSSssssSSSSSsssTTtt" sound. It was the vacum line from the brake booster, and it went from behind the manifold to the brake booster. After this, the smoothest idle in the world.
to check your O2 sensor: Warm up the igne to normal temperature, drive it arround for like 4 mins. then take out the single cable that comes out of the engine. While the engine its running, conect the positive of your voltmeter to the cable fro mthe O2 and the negative to a ground in the car. the car should give you From .1 to .9 volts. anythign lower than .1 its runnign ritch,anythign over .9 its runnig lean. Now if your car always gives you .086 or somethign like .56, your O2 its defenetly gone, and O2 are the major porblem when it somes to gas savings. hope that helps
Old Dec 7, 2005 | 10:01 AM
re037's Avatar
rofl, i like your sig joel
Whattup32526
Nov 14, 2007 01:25 PM
Shri222
Apr 7, 2006 10:59 AM
motegineon
Mar 5, 2006 08:40 AM
240 Freak
Aug 6, 2003 02:14 AM
