KA Cams??
Ive looked for weeks and havent found anything.. i am looking for cams for a KA24DE. Im building up a KA and i am looking for something that will give me a lot for my money...
alot for not alot of money?...
umm.. Stock s13 cams.. you know.. the "hot ones" :( Thats about the best you will get for under $400.. i got a set for 30 bucks from ebay.. |
Originally posted by thekage alot for not alot of money?... umm.. Stock s13 cams.. you know.. the "hot ones" :( Thats about the best you will get for under $400.. i got a set for 30 bucks from ebay.. Edit: Im with Stupid on this one :laugh: Sorry thought that was funny Edit Edit: Im with stupid I like your sig. Still cant think of one...:dunno: |
search for crower stage 3 cams or you could search for gude cams... there are a lot of them out there... and you will spend about 400 to 700 for a set of cams...
http://www.club240.com/forums/showth...threadid=22342 there is a little more info on the cams that ihave found in my searching...
If you chose to keep the stock cams you can always just get higher CR pistons.......
The only reason why the 95-98 can use 91-94 "hot cams" for more power is due to the higher cr of the 95-98....... If you get naps-z pistons "even though they have a lower cr than KA pistons, you can run really high lift cams......... You can go to a machine shop a build your own specs using regrinds.......... |
colt cams makes pdm racing's cams, and will re-machine a set you send in, but it's still around 2-400
