KA Cams??
Originally posted by thekage
alot for not alot of money?...
umm..
Stock s13 cams.. you know.. the "hot ones"
Thats about the best you will get for under $400.. i got a set for 30 bucks from ebay..
umm..
Edit: Im with Stupid on this one Sorry thought that was funny
Edit Edit: Im with stupid I like your sig. Still cant think of one...
http://www.club240.com/forums/showth...threadid=22342 there is a little more info on the cams that ihave found in my searching...
If you chose to keep the stock cams you can always just get higher CR pistons.......
The only reason why the 95-98 can use 91-94 "hot cams" for more power is due to the higher cr of the 95-98.......
If you get naps-z pistons "even though they have a lower cr than KA pistons, you can run really high lift cams.........
You can go to a machine shop a build your own specs using regrinds..........
