KA Shuts Down
Old May 4, 2007 | 08:48 AM
positron's Avatar
KA Shuts Down
After running the car for some time it will just shut down while I'm driving it. This started last weekend. I haven't had another problem until today. I was running some errands and on the way home and it cuts off. Last weekend, I checked it out, oil, MAF, vaccuum lines, spark, etc. Everything is intact but I can't find a reason for the shutdown. Any ideas?
Old May 4, 2007 | 11:43 AM
slimbung's Avatar
is it throwing any engine codes or giving a check engine light. First place i would check is to see if it is throwing any engine codes.
Old May 4, 2007 | 12:09 PM
Did it fire right back up? Are you at a stoplight or are you moving? Under heavy throttle? We need some more details. I was thinking your battery terminals might be the problem.
Old May 6, 2007 | 08:17 PM
positron's Avatar
I was moving when it shut off at regular speed. The check engine light came on the first time it happened.
Old May 6, 2007 | 08:59 PM
dkdeleon's Avatar
check the part of your wire harness that goes across the radiator and fan shroud for cut or bad ground wires. I had same problem a few years ago and found out my fan had been slowlly cutting into the harness.
Old May 6, 2007 | 10:31 PM
so what codes did you get?
Old Jul 26, 2007 | 07:26 PM
positron's Avatar
Hate to ressurect an old thread but I found and fixed the problem. It turned out to be a bad coolant temp sensor. My car would shut down whenever it hit operating temp. It got so that I couldn't drive across town and back without it dying on me. I would let it sit for a hour and half and come back and it would fire up just fine. Well I replaced it and I've been across town and back many times, sat at drive thru's, etc. and no more shutdowns. A $20 fix that takes a 19mm wrench and two minutes to install.
s14Drifter
Jul 27, 2004 11:07 PM
StanBo
Northeast
16
Sep 4, 2002 10:03 AM
-=JRC=-
Feb 22, 2002 06:37 PM
Parsec
Feb 9, 2002 11:22 AM
