ka24de cams
Old Mar 24, 2005 | 07:05 PM
nisilvia's Avatar
ka24de cams
Anyone have a picture of a ka24de cams? I bought a pair from a guy on ebay and when I got it, it looks stock-ish. It has numbers on it a 5 and then a 53p. I think it might be the s13 hot cams. Heres a link of where I got it
http://cgi.ebay.com/ebaymotors/ws/eB...ME:B:EOAB:US:6
I hope I didn't get suckered
Old Mar 24, 2005 | 10:24 PM
BigVinnie's Avatar
Dude those look like CA18det cams, are there cam gears at the end of the cam for belt driven or chain driven....I can't see the pic that well.......
Old Mar 25, 2005 | 03:43 AM
wikd240's Avatar
the cam gears are for a chain and they look like my stock cams... i had the same markings on mine... the 53 p is near the middle if i remember right... like i said they look like mine...but then again that is only a pic...
Old Mar 25, 2005 | 10:54 AM
ProjectMy240's Avatar
look stock cams to me and the title says stage 1 turbo cams. haaha yeah riiigghttttt.
Old Mar 25, 2005 | 05:49 PM
wikd240's Avatar
i have an answer for you on the cams... the 53p is close to the back of the cams... like 2/3rds of the way down... the 5 in your case is in the middle... my old cams has a 2 in the middle...which according to nissan when i checked with them is the stock cam number for my 93 nissan 240... i will call the parts guy that i deal with at nissan tomorrow to see if he can tell me what the 5 means... now this does not matter in regrind cams... because the lobes can be built up and reground... so they could be a different cam profile... only way to know that is to have them measured...and then compare that to the measurements from a known cam...
Old Mar 26, 2005 | 08:27 AM
nisilvia's Avatar
yea i was thinking it might be regrinds too. to answer your questions the 5 is in the middle, and the 53 p is 2/3 the way from the cam gear and it is chain driven
Old Mar 26, 2005 | 08:58 AM
wikd240's Avatar
okay from what my guy told me at nissan this morning... the 5 is from a convertable 94 240 sx... same cam profile as the 93 cams i have... like i said this does not matter for regrinds... i would contact theseller to see if the cams are regrinds or not... ask questions from the source... if i can find my old cams i will measure them for you but i think a friend of mine snatched them up when he was diggin thru my old parts...
Old Mar 26, 2005 | 10:31 AM
BigVinnie's Avatar
Take the cams into a machine shop for proper measurement. Then again you might not of gotten scammed the guy has a phatty seller rating, but it is only at 90.
Old Mar 28, 2005 | 09:57 AM
ConceptS14's Avatar
I have a set of cams, supposedly the hot cams.
i guess intake side has a 1 and a 53F,
exhaust side has 4 and 53F.
if you could get your guy to confirm that these are infact the hotcams, i'd appreciate that a lot. thanks
nisilvia, if you need measurements on the cam lobes, i can do it for you. let me know.
Old Mar 28, 2005 | 11:47 AM
wikd240's Avatar
like i said befor if the cams are "hot" cams it usually means that they are regrinds... nissan did not make a "hot" cam... all i can tell you is what they came from... this will not matter if they have been reground... there are 6 series of cams that nissan made... they might have the same profiles like the 92 to 94 cams... i dont know the diff in the 91 cams other than some people say they are a higher lift and longer duration...
like i said nissan did not make a set of "hot" cams... least none that my guy at nissan has ever been able to identify...
Old Mar 28, 2005 | 01:01 PM
nisilvia's Avatar
so what is the stock measurements?
Old Mar 28, 2005 | 01:55 PM
ConceptS14's Avatar
to my knowledge, the cams from 91-93 KAs (not sure of 94) are termed "hot cams" because of the higher duration.
240/248 verses the 232/232 in the 95+ KAs
Old Mar 29, 2005 | 04:26 PM
wikd240's Avatar
ConceptS14 check your cams again and check that letter my guy at nissan does not know of any of the cams from the 91 to 94 having an f... it should have a p on it not an f... but here again he does not know everything...
Old Mar 29, 2005 | 09:15 PM
ConceptS14's Avatar
just checked. it is an F.
Old Apr 1, 2005 | 11:01 PM
dkdeleon's Avatar
are you sure that its not an infinity cam? there cams fit our cars to
(f cam)
