MIL Codes
Hey, I had three codes pulled the other day from my 98 240sx, P0440, P1440, and P1448. I was told that it would cost close to $600 to fix, I would like to fix it myself but I am unsure of what to fix.
The mechanic told me that P0440=EVAP P1440=EVAP Small Leak P1448=Vent Control Valve however I looked up P0440 and most people say that its the EVAP Small Leak. So now I am alittle confused on who to believe. |
No one?
I've never even seen those types of codes before, did you try just getting the codes using the ECU method and using the list form the FSM?
Well I got a mechanic to do it because I tried pulling the codes once and it never really worked out to good. I actually found an FSM that I downloaded awhile ago and looked at that and it told me what to do. I have to check the Evap Canister to make sure it isn't clogged. I replaced the Vent Control valve 3 years ago thinking that was the problem.
Thanks for your response! |
