my clutch is gone
my clutch is gone
ok going to a friends house on the courtney cambell i shifted into 4th and right when i let go of the clutch and gave it gas it was like the clutch pedal had no pressure on it, i couldnt get any gear and i dont know the clutch is gone, but what exactly do i need to fix i havent checked out the tranny yet, i had all the fluids i need, the spring on the actualy pedal is fine, and there wasnt any burning smell and nothing ovbiously blew up that i know of. help help help
Sounds like you lost your clutch. I blew my friends clutch. At first we couldn't take it out of first. Then we couldn't get it to go into any gears.
Shop for a new clutch. Make sure a throw out bearing is included.
I went for the SPEC stage II from www.enjukuracing.com
Good luck.
Good luck.
well right now the car is in neutral, i brough it to 4th and then i somehow still had enough juice to put it into neutral and after that i couldnt get any gear, my friend suggests it might be the slave cylinder. what do you guys think
How many miles on the car? If you have over 100K and haven't changed it, it might be in need for a change. I have a SPEC II clutch and am purchasing another one for another car. They are great clutches IMHO and worth the $$. But if you have high mileage and felt some grind before then you might definitely need a new one.
yeah i have 125k on my car, the previous owner of the car was an older lady who only performed basic maintence so i probably will need a new clutch. When this happened i couldnt remember if there was a grinding sound, it all happened so quick, all i remember happening is when i was in 3rd, i was getting ready to put it into 4th, i stepped on the clutch and tried to put it in 4th but wouldnt let me so it just went into neutral, then i let go of the clutch and theres no pressure to bring it back up. now that i think of it thats was happened. i dont remember a grinding noise though.
well its funny because i was with my boy and we had gone to a maxima meet... his clutch was acting up just like u said... well we had a lexus tech there... he determined it was his master cylinder ... it cost him about 150 to fix... not quite sure... but it was between 100-175...
hey guys, i checked it out, and my clutch is blown to pieces, so i can only get a hold of another stock 240 clutch for the moment so that will have to do. i was praying that it was the slave cylinder, and another problem , my started pretty much blew up also, the core is totaled, the thing that bugs me is that the car used to start untill now.
well to start the clutch is not needed. all that is needed is the neutral position switch being activated. And as i Though I was right. Hate to hear the car is immobile, but once you get the new one, you'll be alright. Are you going to try it yourself to fix or have a shop to do it?
240SEX How much did you spend on the ACT and what level/stage?
Jonas If time is not an issue I would get a stronger clutch while you car is up on the lift getting worked on. Might want to think of a flywheel while you are at it.
