Need Injector Help!!!!
Old May 8, 2006 | 11:41 AM
revolutionz_s13's Avatar
Exclamation Need Injector Help!!!!
i am having a problem. i have a 1995 KA24DE in my 92 coupe, and my #2 cylinder is dumping fuel. I currently am using sr20 370cc injectors, detuned witha safc2.
as far as i can tell from tracing wires, everything seems to be good. i have metered all my injectors, and they all read 11.9ohms. i have replaced the o-rings on the injector also. the problem seems to be intermittent, if i let the car sit for awhile, its runs fine for a bit when i start it. after a bit, it will start flooding again. i have tried: new injector, checking the wiring, checking the MAF, new cap & rotor, checked for spark, new plugs, checked the wiring, cleaned the injectors.....im out of ideas. any help would be appreciated. im starting to think the ecu might be the culprit, but what would I test for?
Old Feb 21, 2013 | 08:21 PM
s14-obd1's Avatar
I am in the same boat but all of my injectors are stuck open same thing i need help Some one help us please! poeple say i need a new ecu but mines a 1995 se obd1 and no one has my ecu for sale i got money but no ecu!
homesliceisj
Jun 22, 2007 02:50 PM
trevr
May 25, 2007 02:51 PM
trevr
May 18, 2007 02:50 PM
jackyliem
Dec 29, 2006 11:22 PM
revolutionz_s13
May 6, 2006 05:46 PM
