Need Some Advice For Overheating Problem & Engine Running Very Sluggish
Old Aug 23, 2005 | 11:45 PM
FlyingS13's Avatar
Guys, I need some of your expert advice on this. My car have the 2.4L SOHC engine. It just keep on overheating. The fan is working. I flushed the radiator. Replaced the thermostat. The engine is still overheating whether I'm driving on local, highway, with, or without turning on the A/C.
Also the engine can be very sluggish. Sometimes even when I hit the gas at full throttle, the car just don't want to go as if like the asphalt full of glue or something I already did a tune up on my car & it's still like that. It doesn't feel my auto tranny problem though. It doesn't skip gear. Actually the tranny still shift pretty smoothly.
I was thinking about replacing the fuel filter. What do you guys think of it? Where is the fuel filter located for the 89 S13?
Any advice from you guys would be really appreciated. Thanks a lot guys
Old Aug 24, 2005 | 12:05 AM
Is your water pump working? Also sounds like it could be a blown headgasket...
Old Aug 24, 2005 | 12:34 AM
FlyingS13's Avatar
Yea, I'm gonna check on the water pump. I didn't check or change it yet.
The thing about head gasket, I didn't lose any coolant though. Not even a little bit.
Thanks for your fast reply
Old Aug 27, 2005 | 05:53 PM
dkdeleon's Avatar
when you filled your radiator did you loosen the burp hole screw and fill untill water came out of the burp hole???
if not that is your problem, no coolent in the engine
Old Aug 27, 2005 | 09:56 PM
BigVinnie's Avatar
Defenitely sounds like......
Low coolant, or
needs new water pump, while yer at it
get some water wetter.............
zako
Apr 24, 2007 10:40 AM
thekage
Sep 7, 2005 03:00 PM
jmhayes
Nov 24, 2004 04:02 AM
DRiften
Jul 30, 2004 09:20 PM
